boost gauge question....
Old Nov 7, 2000 | 09:19 PM
maniacc's Avatar
O.K. i need some ideas of where to install my boost gauge in the plenum....is there a available hole that can be used or do i need to drill and tap one????
thanks all,
later,
MÅN¡ÅÇ ©
88 IROC 5.7L,edelbrock TES,random tech cat,borla exhaust,chip,sfc,accel wires,airfoil,k&n's,ETC..
and soon to be supercharged
http://maniac.megamania.com
Old Nov 8, 2000 | 01:36 AM
89ProchargedROC's Avatar
i have always been told that the best place is to tee into the fuel regulator vacuum line. that is where mine is and it works fine
Old Nov 8, 2000 | 07:09 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
The two existing vacuum ports on the plenum are for the fuel pressure regulator and vacuum tank. It does not matter which line is teed into as a source for a gauge. Vacuum is vacuum. The vacuum tank line is easier to tee into because it's rubber and it runs along the firewall by the brake booster. There is an access hole in the firewall below the three-relay bracket (close to the vacuum line). If you tee into this line, it is out of sight if you tee into it near the access hole. Make sure it's between the plenum and one-way check valve, not between the check valve and vacuum tank.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://www.ozemail.com/au/jca69/mods/williesz/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
$750 L98
Feb 1, 2025 02:25 PM
Bubbajones_ya
Jul 6, 2024 08:32 PM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
