Supercharge or more CI?
Old Nov 8, 2000 | 10:43 AM
Josh 91RS's Avatar
Wondering what is more powerful, and which one is more financially feasible between supercharging a 350 or getting the stroker kits to make it a 383. What is the price differences? What is the performance difference between a supercharged 350 and a stock 383? How much work does it take for either one? Can a stock tranny and rear end on a 91 rs handle the horses from either of these, if not what needs to be done?? Any other sugesstions?
Old Nov 9, 2000 | 12:17 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
383 will make more low end torque and you will have a strong low RPM engine. If you go with a SC you will have a power increase in both upper and lower RPM's.
A SC will probable cost a little more depending on which parts you will choose for the stroker kit.
Some people says A stroker and a miniram will give you the same power as a SC but with less headaches, but the miniram isn't cheap and will give you the upper RPM power.
I'm going to rebuild my engine soon and have the same thoughts as you and for the moment I will go for a 355 with forged stuff and a ATI 9 psi kit.....
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
InfinityShade
Feb 21, 2016 01:29 PM
toronto formula
Nov 10, 2015 06:17 AM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
