L98 with a turbo, anyone got any advice?
Old Dec 15, 2000 | 01:20 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
If I were to get an L98, what would be needed to slap a turbo on it? From a completely stock point of view... How could it be done? What would be needed, how much boost would it take to get it faster than a dang TTA!?
Planning an L98 swap for my car, and seriously planning ahead. Its always best to do it right the first time! I dont want to have to re-pull the engine after I get it in!
P.s. why dont I ever hear about any v-8's that respond as well to turbocharging as the 3.8?
http://kiztope.50megs.com
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!!
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14(?))
"No one knows until they learn" Leon Calrinsky (99)
Old Dec 15, 2000 | 11:54 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
There's the obvious, such as the turbos, Y-pipe, downpipes, wastegates, dump-tubes, oiling lines, intake, changing to a custom computer or MAP system with a custom chip, and relocating everything you can think of to fit it in.
V8's respond great to turbos! It's just that there was no easy bolt-on kit currently, so you don't see too many of them. I built a twin turbo setup on a basically stock L98 engine (Super Ram intake), so I'm limited to very low boost (dang cast pistons!). I have the wastegates set at 5 psi, and it'll generally overboost to around 7 psi in the summer. My one and only good day at the track had me spinning all the way through 1st and 2nd, forcing me to shift into third at 3000 rpms. The 1/8 mile was 9.0@86 mph, while the 1/4 was 13.4@114. With decent tires (I tried a drag radial and snapped the axle) and a better program in the DFI (I had a super-rich, low timing daily driver program in there at the time) I should pick up another 4 mph or so. On a fairly stock L98. The engine is in its death-throes right now, chugging smoke every now and then, getting oil-blowby, etc... We'll see if I can get a good pass or dyno run before it explodes
Andris Skulte
Skulte Performance Designs
Z28tt-89 IROC T56 DFI Twin Turbo
http://www.skulte.com
Old Dec 15, 2000 | 11:13 PM
Basett Racing's Avatar
Where did you get the Turbos from?
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
http://www.bassettracing.cz28.com
Old Dec 17, 2000 | 04:20 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
You can't slap a Turbo on anything and expect much. It takes lots of study to get it right. Doing a TTA type drivetrain saves 150 lbs off of the front end. A TTA is a neat car, and just does so much right, why reinvent the wheel?. Going the TTA makes it a bolt together of KNOWN items.
BTW, if anyone is serious about somthing like this I have a bunch of the items to do it, write me off list if your really interested
Old Dec 19, 2000 | 10:19 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
I have the Turbonetics TO4E turbos, 0 Trim, 50 series, .58 ar
Andris Skulte
Old Dec 19, 2000 | 08:39 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
So what kind of 1/4 times have ya'll gotten with a single turbo? (on an L98)
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
Mr. Chevy
Sep 11, 2015 06:06 PM
tgp1990
Sep 4, 2015 06:24 AM
mrdevontay
Sep 2, 2015 08:04 PM
