building mild 350 TPI, NO2 safety ???s w/in
Old Dec 10, 2000 | 02:58 PM
mike88RS's Avatar
Im in the process of building a mild 350 tpi for my 87 z28. Im using 64cc centerbolt heads, flat top cast(might go hypereutectic, not sure) and a 218 224 cam with 112 sep and 480 lift. as for the efi,im using an afpr, 19lb injectors(off my 305 setup, they have less than 500 miles on them)brand new fuel pump/sock/filter/newer fuel pump, mildly porting intake and im hoping for an accel super coil, might even get a 6a if I can get the cash up. the tranny is a 273(277?) posi, and an auto now with a WCT5 in the garage waiting on pedals. my question. with roughly 9.5/10-1 compression, and the combo I described, would a 75/100 shot of NO2 be dangerous to the motor? would I be grenading a new motor or is this safe? please let me kno any thoughts, as this about a month from now
mike
Old Dec 10, 2000 | 07:14 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
The engine build should be ok with nitrous use if assembled correctly. If in doubt you may want to consider forged pistons for the added safety factor. I don't think you mentioned upgrading the fuel system. A performance fuel pump will help prevent fuel starvation. A lean condition will destroy any motor but is certain dooms day for a nitrous motor. You can get a 255 ltr/hr pump for a resonable price. You didn't mention if you intended to use a dry or wet system. Off the shelf wet systems are designed to run stock fuel pressures. Less than stock pressures will create a lean condition and greater than stock pressures will create a rich condition. To use the 19 lbs/hr injectors you will likely need to increase fuel pressure or use a custom prom. you might want to consider larger injectors. The stock 350 injectors are 22 lbs/hr. Alot of people use SVO 24 lbs/hr injectors because of their low price. If you intend to use a dry nitrous system you will certainly want to use larger than 19 lbs/hr injectors.
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
[This message has been edited by IROCKZ4me (edited December 10, 2000).]
Old Dec 19, 2000 | 11:34 PM
86_327_camaro's Avatar
i think that a mild rebuild or a stock engine is supposedly capable of a 125hp shot of nitrous. thats cast crank, cast pistons, stock rods. the hyperuwhatevers will hold a little more nitrous i think
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
