What combo would you go with?
Old Dec 6, 2000 | 11:13 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Hypothetical here, just seeing what some combos might look like and cost. The object is to haul as much *** as possible both on the street and the strip w/ pump gas. The things you HAVE to work with (ie. these are set in stone):
1) An ATI Procharger D-1 w/ 3 core intercooler w/ 20 psi of boost
2) A mini-ram intake setup
3) AFR alum. heads (size not yet determined)
4) A Ford 9" rear (ratio not yet determined)
5) A bulletproof 700R4
Now, the questions:
1) What size engine would you choose:
355 or 383?
2) What size AFR heads do you choose? And what compression ratio do you want?
3) What cam do you go with?
4) What stall speed do you pick for the TQ converter?
5) What gear ratio do you put in the rear end?
6) What size fuel injectors do you get?
7) How much does LABOR cost to just put the ENGINE together?
[This message has been edited by BuckeyeROC (edited December 06, 2000).]
Old Dec 19, 2000 | 11:50 PM
86_327_camaro's Avatar
well as far as engine size i would think that its more a question of how much $$$ you wanna spend. you can make a short rod stroker ( 400 crank and rods) and use .030 350 pistons or go with the 5.7 or 6" rods which will run into more$$.
i think that your compression should be between 8:1-9:1. might want to go with a dish piston and 76cc chambers.
i had some more #s for cams and such for nitrous/forced induction systems but i can't fine em right now.
as far as rear gear, if its a street/strip with a 700r, i would go with a 3.73 or 4.11. but i think that there was a post on another board about speedo gears with a 700r and 4.11 gears. so you might want to think about that also.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
