need help with 6al and btm install
Old Dec 28, 2000 | 12:50 PM
DeathMobile's Avatar
how do i hook up the coil wires and the magnetic pickup wire or the timing wire?
All I have to work from is the diagram on the bottom of the 6AL, and it shows things very simplified for a carb setup.
Also, where is there a boost source on the manifold or engine??? To hook up the btm and the boost gauge, it says i should hook into a pressure source on the manifold or engine.
DeathMobile, aka TheWraith
Old Dec 28, 2000 | 01:22 PM
z/28cwby's Avatar
If you go to msdignition.com, you can download a set of instructions. I could tell you here, but it would be a tad bit complicated without actually seeing the diagram. There are different set ups for vacuum advance, electronic advance, 5 pin modules, and 7 pin modules.
1984 Z/28
GoodWrench 350, Edlebrock Performer intake, MSD 6AL Super HEI kit, Crane CompuCam 2040, Edelbrock headers, Catco cat, Flowmaster aftercat, K&N, Custom 700R4, B&M Megashifter, Eibach springs, Energy Suspension Hyperflex kit, KYB GR-2 struts/shocks, Jegster adj LCA's, Lakewood adj panhard bar, BFG Comp T/A's, 180* stat, AutoMeter Pro-Comp COOLANT GUAGE.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
