those of you with a btm or boost gauge
Old Dec 28, 2000 | 04:26 PM
DeathMobile's Avatar
where do you hook up for boost? The instructions for both the btm and my boost gauge mention a boost source on the intake manifold or on the engine.
Where the heck can i hook up to?
btw, this is for an L98...
DeathMobile, aka TheWraith
Old Dec 28, 2000 | 07:56 PM
gtaguy's Avatar
You hook them up to a vaccuum port on the manifold. I have a superram and hooked them up to a 3/8 port on the back of it.
-Matt
Old Dec 28, 2000 | 10:42 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
On a stock plenum the manifold vacuum ports are located at the rear right side of the plenum. You can tap into one of the hoses with a "T" fitting.
Tracy /AKA IROCKZ4me
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
My IROC-Z
EFI Performance Club on Yahoo
Old Dec 29, 2000 | 05:31 PM
thanks for the help. I tapped into one of them, and the gauge is working, but it seems to be reading 20 on the vacuum side at idle.
Is that normal???
Old Dec 29, 2000 | 09:23 PM
IROCKZ4me's Avatar
That's good vacuum. Most engines with stock or near stock cams will idle with around 18"-22" of vacuum. Camshafts with bigger duration numbers & tighter lobe seperation will have more overlap & therefor lower vaccum at idle.
  • 355 cid
  • AFR heads
  • fully balanced
  • SLP cat-back
My IROC-Z
$750 L98
Feb 1, 2025 02:25 PM
Bubbajones_ya
Jul 6, 2024 08:32 PM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
