Can a CCC quadrajet supply a supercharger enough gas down the strip?
Car: 1985 Z28
Engine: 383 forged, B&M 144 supercharger
Transmission: Art Carr 700 R4
Axle/Gears: 9 Bolt G92
I am contemplating using my CCC quadrajet on top of a 144 B&M roots blower on my stock 350. I've been told that the carb might not supply enough gas and to go with a DP holley. If my set up goes lean the engine's toast from detonation. Your opinions please.
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
I'm sure you will get lots of replies suggesting a holley. However, A CCC Q Jet uses the same secondary metering rods and hanger as the early Q Jets and also the same as the Edelbrock performer Q Jets. Therefore parts are easy to find. The same old tuning tricks that work on the old Q Jets work on the CCC units too. Like filing a notch in each secondary airvalve above the secendary enrichment orifices, enlarging the orifices, or filling the original orifaces with epoxy and drilling new orifaces below the air valve blade.
Get a good book on Q Jet tuning. All of the accelerator pump and secondary tuning tricks will work for nonjCCC and CCC Q-Js, and alot of the primary tricks and idle circuit tricks can be applied too.
Be sure to get a better fuel pump.
The major drawback to the Q-J over a Holley is bowl volume. A better pump will prevent you from draining the bowl faster than the pump can fill it.
Tracy /AKA IROCKZ4me
EFI Performance Club on Yahoo
Club IROC-Z
- 355 cid
- AFR heads
- Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
- modified SLP runners
- TRW forged pistons/ceramic coated
- fully balanced
- Edelbrock headers/ceramic coated
- SLP cat-back
- Paxton supercharger
- Nitrous Express nitrous oxide
Club IROC-Z
Car: 1985 Z28
Thanks for the reply. Your right in that holley even needed to be modified for superchargers. They now make supercharger ready carbs. I think that the Q jet could be modded.
The fuel pump is a edelbrock 1721 with 110 gal per hour capacity. I plan to use a marine water seperator filter as an inline filter - it holds about 1 qt of gas.
144, 355, 383, afr, b, carb, carburetor, ccc, heads, nitrous, quadrajet, set, supercharger, superchargers, supercharging
