The Beast is alive and well!!! (so far)
Old Jan 11, 2001 | 08:08 PM
Twin Turbo 358's Avatar
ok, i'm keeping my fingers crossed. i fired up my car last Saturday! i had a couple problems that i ran into (leaky fuel fitting at the rail, and leaking around the heater core), but i fixed them last night. we set the base timing, idle, fuel pressure last night. i haven't taken it for a spin yet, but hope to do so soon. it sounds very healthy! the idle is just under 1000 rpms and isn't too lopey, just a little rough but nothing outrageous. i've still got a small list of things to do:
replace broken coolant temp sensor
mount the variable injector controller
reseal the tranny pan (someone used permatex AND the cork gasket!!!)
fix a leak from the tranny cooler
finish wiring up my dual (R/L) air/fuel guages
put the rest of the exhaust on
fab the intake tubes from turbos to TB
install spool in the 9"
weld subframes
hopefully i'll have most of this done by the Georgia F-body shootout on March 11. i'll have dyno #'s by then as well!
Jeff
99 T/A WS6 A4, RKSport lid & free EGR mod
88 GTA twin turbo 358, forged crank, forged H-beam rods, Wiseco reverse dome pistons, Dart Sportsman II 72cc heads, Comp Cams custom grind blower cam (.560/.586 lift, 232/236 duration), 1.6 roller rockers, TPIS mini ram intake manifold w/ Accel 58mm TB, 83 lb injectors, Accel DFI computer with variable injector controller, 2 Garrett T04B "hair dryers" with dual Garrett wastegates, TH400 tranny with BTE transbrake and Art Carr custom converter, F*rd 9 inch rear w/ 3.50 gears, and more...
Old Jan 11, 2001 | 11:30 PM
GMI FAST's Avatar
Good job, dude! Post some pics of a nice, smoky holeshot once she's broken in. Tell me you were a good boy and rerouted those oil feed lines...
Old: 1989 Formula, 383", DFI, built 700R4, TFS heads, Mini-Ram, Vortech S-trim 15 psi, 3.70 gears
Best ET: 10.796 @ 125.8 mph
New: 1989 T/A, 406", Accel Pro-Ram, DFI, AFR heads, HRC Turbosystem, NOS 150-hp dry kit, TH400 w/GV overdrive, 9" w/3.70 gears, 8-pt. S&W rollbar, 18" wheels
Best ET: Spring 2001
Employed at:
Hahn Racecraft
Accel EMIC/DFI Tuning
Turbosystems & Custom EFI
Member of Midwest F-Body Association www.mfba.org
Old Jan 16, 2001 | 07:02 PM
GMI Fast, no i haven't rerouted those oil lines yet but you'll be glad to know that it's on the list of things to do! it's a simple fix--i just haven't had the time yet to do it. thanks for the input!
Jeff
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
GTAman
Mar 15, 2019 11:40 AM
lt1z350
Sep 29, 2015 01:50 PM
BLK87Z
Sep 18, 2015 11:29 PM
Thirdgen89GTA
Sep 12, 2015 08:39 PM
