Willie and Guido...need your opinion
I'm getting a custom chip burnt as we speak and the burner needs to know what spark advance to try for WOT. I'll be running an MSD boostmaster as well. Mods are in my sig.
Thanks for any help guys. I'll be running 10#s of boost by the way with SVO 24# injectors
Ryan
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN93, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP headers & catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
[This message has been edited by theformula (edited February 07, 2001).]
Ryan
91 Formula
305 TPI 5speed
1LE/G92/WS6
Car: 1987 Z28 Convertible
Transmission: 5-speed
Originally my TPIS Level V PROM was burned with 24 degrees of advance, for a total of 30 degrees with base timing set at 6 BTDC. I discovered very quickly that I could run much more advance than 30 degrees, so I had the PROM changed to 30 degrees. With my adjustable timing module, I set my base to 8 BTDC or a total of 38 degrees.
Because you'll be using a BTM (I can't imagine why you'd do this, but that's another issue), go for an aggressive advance and have the BTM retard timing.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://members.optushome.com/au/downunder1/rides/willie/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Willie
12.57 @ 111 mph.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
skinny z
Oct 5, 2015 06:23 PM
