juice on now what!!!!!!!
Old Feb 9, 2001 | 12:24 PM
trevor92rs's Avatar
i just put juice on my stock 305 tbi i want to know what i could by to make it safer the first time i use it. ive had it for two days and am scared to use it its ajustable from 75-125 and its on 100 now the guy that sold it and put it on says my engine could handle it but im not sure what would be a safer way to use my juice!! thanks my engine just hit 70,000
Old Feb 9, 2001 | 12:44 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Your 305 will handle a 100 HP shot of spray as long as your ignition and fuel system is in good working order. You should also run a step colder spark plug than what thae factory calls for and retard your timing about 2-3 degrees. Just make sure your getting enough fuel because lack of fuel is what causes most NOS engines to fail.
Old Feb 10, 2001 | 09:23 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
The most important things to check out is the wires going to the soilnoids, especially the fuel solnoid. Maybe go through with a test light and make sure everything works (With the bottle off). Making sure these wires stay put is good insurance (solder). A fuel pressure guage is helpful in making sure pressure doesn't "fall off" while your spraying. Change your fuel filter more frequently. Start with the 75hp and work up, but remember not to get "nitrous fever" a.k.a. pill it 'till ya kill it. Ignition mods are top priority (good wires, coil, aftermarket CD if funds allow). Never spray with the engine off. Don't start it if you do (purge it by removing the coil wire and gas to floor crank several seconds)
These levels of augmentation seem pretty safe even if something goes wrong, but it's better safe than melted. Happy sprayin' let me know how much faster it feels!!!
JSDaddy189
Sep 26, 2015 03:50 PM
GofasterFirebird
Mar 16, 2002 09:32 AM
IROC-KET
Nov 27, 2001 04:31 PM
chevyboy07 91
Apr 10, 2001 03:19 PM
chevyboy07 91
Apr 2, 2001 04:46 PM
