Oil control - vaccuum suction, exhaust bungs...
Old Feb 5, 2001 | 12:29 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Hey guys (GMI_Fast in particular),
While daydreaming here at work, I read one of GMI's posts about his rice car components being "oil control" stuff... I've been having problems of oil blowby going through the breathers and onto the valve covers (yeah, I know, rings are probably pretty worn, and I need a new engine, but in the meantime...) What I've been thinking of doing is either a vacuum pump from a diesel engine hooked up to the valve covers and sucking through a separator (which drains down to the pan) or one of the exhaust bungs that creates suction as air moves by. Have any of you done that yet?
Andris, with wastegates, dump tubes, blow off valves, and eight 4" diameter cylinders
PS-I've got a Canton road race oilpan, with windage tray, 3 trap doors, etc...
Andris Skulte
Skulte Performance Designs
Z28tt-89 IROC T56 DFI Twin Turbo
http://www.skulte.com
Old Feb 5, 2001 | 03:52 PM
Jester's Avatar
I made one that worked rather well out of my old smog pump. If you want a cheap way just to try it out, or for a temporary help, that might be one option. I didn't have an oil sep. though...made a mess.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Feb 12, 2001 | 06:10 PM
BLACKSUNSHINE's Avatar
I have a good idea for that very problem.
I was working on a 4th gen trans am and noticed they use an electric powered smog pump it actually looks like a little super charger. And I pulled off the intake side of it and it pulls a really strong vacume! prolly like 5inches I would say and a large volume of air also it has a3/4 inch or so in let on it .
I have the same prob , blowing the occasinal dreded oil. that would solve all our probs! when I find out a part # I will let you guys know!
91 Black Pearl Z
5 spd
low miles
9psi ProCharger
3 row intercooler
paxton BTM(MSD)
MSD blaster2
ROH Snipers
Drilled rotors
350rwhp/400rwftlbs 305 Baby!
The Darkside
Old Feb 12, 2001 | 07:34 PM
Twin Turbo 358's Avatar
Andris, mine does the same thing. i tried to use regular breathers but it got too oily on the valve covers. i put the "PCV" style breathers back on until i can figure out a better solution. what about using the PCV style with a "catch can" mounted somewhere? i think i saw one on a turbo buick in a magazine once...
Jeff
99 T/A WS6 A4, RKSport lid & free EGR mod
88 GTA twin turbo 358, forged crank, forged H-beam rods, Wiseco reverse dome pistons, Dart Sportsman II 72cc heads, Comp Cams custom grind blower cam (.560/.586 lift, 232/236 duration), 1.6 roller rockers, TPIS mini ram intake manifold w/ Accel 58mm TB, 83 lb injectors, Accel DFI computer with variable injector controller, 2 Garrett T04B "hair dryers" with dual Garrett wastegates, TH400 tranny with BTE transbrake and Art Carr custom converter, F*rd 9 inch rear w/ 3.50 gears, and more...
eightsixseven
Dec 16, 2024 01:50 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
