fresh 355, spray and fuel options?
Old Feb 13, 2001 | 01:44 PM
Superblue87Formula's Avatar
I am putting togtether my new motor and I want to know how much NOS I can spray and what it will net me in the 1/4:
L98, .030 over
reconditioned rods, polished crank
9.75:1 forged pistons w/ valve reliefs
zz4 cam
weiand stealth intake
I was figuring on going with a 150-200 shot of nitrous, but I am guessing this will fuel starve my motor.. can I use an inline fuel pump to keep it safe? I'd prefer not to drop the tank, but I'm probably going to take the rear out anyhow so if I have to, I have to..
1987 Formula 350, headman hedders, Accel supercoil, cap, rotor.
MAF screens removed. 160 degree stat and manual fan switch.
Best ET: 14.745@91.317mph-Stock
Best ET: 14.418@95.51 mph-Modded
Ridiculed Founder of the Traction Impaired Crew
Old Feb 13, 2001 | 01:52 PM
Guido's Avatar
Car: 2000 Trans Am
I see you swapped to a carb. So... have you replaced the intank pump already with a low pressure one? Or are you using a regulator or something to regulate the pressure down?
Im not sure how to setup nitrous on carbed cars. But I thought Id bring up a few points.
-86 IROC
Vortech Supercharged 406
-=ICON Motorsports=-
Old Feb 13, 2001 | 01:55 PM
I'm using a return-style regulator to get the pressure down
Old Feb 16, 2001 | 11:32 PM
come on, I know someone knows the answer to this!
Old Feb 17, 2001 | 04:28 PM
87formula383's Avatar
Need more info: If you are using an in-tank pump designed for FI and you have a carb set up, you sould have plenty of fuel pressure tapping into the fuel line just in front of the carb,(that is,asuming you have an NOS system designed for a carb?).A carb designed NOS system (power shot) is made to work off 9-12PSI fuel presure just by an in-line tap.even if it was an FI NOS system you would have plenty of fuel pressure with an in-line tap.(up to 200hp shot)...asuming your fuel pump is healthy.
Old Feb 17, 2001 | 04:37 PM
Also for comparison sake, when my 87 Formula was just a 350 with the same cam you have and a superran intake it ran a 14.5 1/4 at 95 MPH on motor.....13.1 1/4 at 109MPH with a 175HP NOS system....Hope that motivates you.
Old Feb 17, 2001 | 10:35 PM
thanks, as per a different post by "the ODB" I am going to use two carter electric pumps pulling through my stock pump, one for the NOS and one for the carb.
<font face="Verdana, Arial" size="2">Also for comparison sake, when my 87 Formula was just a 350 with the same cam you have and a superran intake it ran a 14.5 1/4 at 95 MPH on motor.....13.1 1/4 at 109MPH with a 175HP NOS system....Hope that motivates you. </font>
damn, my car was knocking on 14.3's (no traction) stock with headers. I am hoping the cam, plus the ci and compression boost will put my in 13's on the motor. I am running slicks so I think I'll be okay
with the slicks and a 2800 stall, as well as lots of suspension mods, I'm hoping the 200 shot will break me into the 12's
92camaroJoe
Jul 29, 2023 07:57 PM
Reddeath210
Oct 6, 2015 08:20 AM
theurge
Aug 21, 2015 12:46 PM
92camaroJoe
Aug 13, 2015 06:07 AM
