inlet oil line
Old Apr 24, 2006 | 04:57 PM
personoo's Avatar
inlet oil line
i was wondering if anyone use a filter on the oil inlet to the turbo, if so what type and where can i get one. i will be running a -4 line from the oil sending unit.
thanks for your help
Old Apr 24, 2006 | 05:24 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Why?
Don't you trust the engine oil filter?
Old Apr 24, 2006 | 07:13 PM
KillerZ302's Avatar
Car: 1988 Iroc-Z and 1985 Z28
Engine: Mild TT 355 and Built 383 Superchar
Transmission: Manual
Remember. Oil first is picked up by the engines oil pump and then its routed thru the oil filter (well at least half,some engines are different, summit sells a check valve thing that will not let the oil be bypassed by the filter) and then goes into the engine which includes the oil pressure sender port at the back of the block. There is no need to filter the oil again. Its already filtered. That would just be a restriction and cause the turbo to get even less oil.
No filter man!
Old Apr 26, 2006 | 12:13 AM
personoo's Avatar
i thought the oil went to the sending unit first,my mistake thanks for the info.
solocus
Sep 2, 2015 12:14 PM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
