how hard is it to install a supercharger?
Old Apr 3, 2001 | 12:29 PM
89FormulaL98's Avatar
im thinking of buying a vortec s-trim for my car, and i want it installed right. Im just woundering how mechanically intensive it is to install a charger. Im not the best when it comes to doing engin work, but i do do most things myself. After the actual thing is installed, is there loads and load of configuaration to do to? and one other thing, i have a hypertech chip installed in my car, will this have to be removed befor installing a supercharger?
89' Firebird Formula WS6 L98, MSD 6AL MSD Blaster, Hypertech chip, K/N filter cone,flowmaster 80 series, hypertech air foil, koni shocks, edelbrock trailing arms
more to come soon.....
My temporary P.O.S. website: www.angelfire.com/il3/DuPageSpeed
Old Apr 3, 2001 | 03:46 PM
Guido's Avatar
Car: 2000 Trans Am
The only real tough part is putting the hole into your oil pan. I had my engine out and welded a coupling onto the pan to screw the fitting into but vortech says to punch a hole and use a tap to thread the material you push in. They say to pack the tao with grease so that it will grab any metal shavings.
Other than that, its pretty straight forward as long as your mechanically inclined.
Good luck!
-86 IROC
Vortech Supercharged 406
-=ICON Motorsports=-
"Well, you're equipped to be a prostitute, but you're not one, are you?"
toronto formula
Nov 10, 2015 06:17 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
db057
Aug 22, 2015 08:17 PM
PestilenceIV
Aug 20, 2015 02:33 AM
