Which cam - 383 and Procharger
Old Apr 2, 2001 | 02:09 PM
a73camaro's Avatar
I have the Procharger and it is going on a newish 383 (350 with a 3.75" stroke). I am guessing compression will be around 8.2 - 8.5.
Iron heads (993's) and an aftermarket TPI (large runners).
There are two cams (flat hydraulic tappet) from Crower. One is rated at 5-10 psi boost. The other is 10+ psi boost.
I'm not sure where the boost levels will be at, but I want to run as much as possible. I'll stop at 15 psi, maybe.....LOL
This is going on a boat and I'll be adding a intercooler (air to water) soon after.
What have you guys run? I also need a descent idle from the engine.
Old Apr 3, 2001 | 08:00 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
i run a fairly large cam on mine and i run
14 psi.
you can find it on my web page.
Check out my simple page at:
http://darcom.home.texas.net/
388 SuperRam, DFI, Vortech R trim ,N.O.S.,alki injection,
Dart sportmansII heads,50 pound injectors, Headman full headers
duel 3' exhaust,and Flowmasters, Ford nine inch with 370's
Ronal rims with Nitto drad raidals.
Jorlain
Oct 8, 2015 01:57 AM
abray1
Sep 10, 2015 04:53 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
