window switch range set at what?
Old Apr 3, 2001 | 12:56 AM
Kandied91z's Avatar
for everyone with nitrous, what is your range that your window switch is set up at?
Old Apr 3, 2001 | 10:16 AM
Formula-91's Avatar
That's all gonna depend on your motors characteristics. I have a friend running a solid cam and turning 7200 rpm out of his LT1. He's spraying from 3800 to 7100. Mine hits at 3500 and cuts out at 6250. If you're talking about a stock 3rd gen motor, I don't think I'd set it much higher than 5800. You're not gonna be shifting that high anyway, and you don't want to over-rev.
Old Apr 3, 2001 | 09:08 PM
Kandied91z's Avatar
i guess i'm more worried about the starting point! anybody?
Old Apr 3, 2001 | 09:16 PM
Bob Wooten's Avatar
As soon as you can bring it in w/o taking the tires up in smoke. If you have the suspension for it, out of the hole.
BW
Bob Wooten
71 Camaro, 91 EFI, 01 HP
r71chevy@earthlink.net
www.r71camaro.homestead.com
Old Apr 4, 2001 | 12:39 AM
Kandied91z's Avatar
do i set it up to go right after a shift, or right in the middle?
Old Apr 4, 2001 | 01:34 AM
Bob Wooten's Avatar
not sure i am following. in the middle of the shift or rpm range? i assume that you mean rpm range. i would say as soon as you can. if that is right after you shift then bring it on. if you do that & the tires go up in smoke (probalby not likely, maybe right out of the hole it would if it is going to) then wait a bit longer.
Bob Wooten
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wylecoyote08
Aug 14, 2015 08:28 AM
