In line fuel pump question?
Old Apr 11, 2001 | 02:16 PM
RenoLB8's Avatar
I was sitting in spanish today making my endless lists of parts and plans for the SC'ed L32 project (no flames guys, this is for the fun of it), and I was thinking I'll need a pump that will give high pressure, so wouldn't it be nice to just have an in-line pump, rather then some damn in-tank monstrosity? My other question is could I hook up the in-line pump, and just disconnect the in-tank, or would I have to remove the in-tank, too? Thanks ahead.
-Reno
'88 Firebird LB8
"Cerberus"
-Supercharged Hybrid LB8/L32 Project-
"Got a green light, got a red light, no cop, no stop, man I don't care, every one of you could be the same, every one of you could play this game, got a green light, got a green light but you're going nowhere..."
http://www.angelfire.com/il/Firebird28/index.html
Old Apr 12, 2001 | 04:26 PM
MouseCamaro305's Avatar
Just run a good intank pump. Otherwise your fighting each other by running two pumps.
even if you disconnect the other pump you would be better off installing a higher output intank pump. You should also have an adjustable fuel pressure regulator, but otherwise it will not need to be changed.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
