nitrous switch question
im thinking of goin with a 150 shot of nitrous with all the bells and whistles(remote bottle kit, heater, purge)
im trying to make a list of the switches i need
1 to open the bottle
1 to activate the system(on the b&m megashifter handle)
1 for the heater
1 for the purge
are there any that im missing
also i was looking in summit and they have a switch board from moroso with 5 switches and on momentary switch for the purge
any ideas where to mount the panel(i was thinking underthe vents in the middle of the dash)
1987 Camaro IrocZ
B2L 350
90 corvette Engine swap(ground crank on original)
borla catback
free hp mods
modefied airbox
jet airfoil
tag: EYEROCK
Words to live by:"The surgeon general never said anything about smokin a ford"
1 for the heater
1 for the purge
1987 Camaro IrocZ
B2L 350
borla catback
free hp mods
modefied airbox
jet airfoil
tag: EYEROCK
i mounted mine in the vent holes, just took the vents out and drilled some holes. it looks trick. BTW i suggest a WOT microswitch on the carb to activate it, you get more consistant runs this way vs manually controlling it by the shifter switch.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
Get the NOS fuel pressure safety switch. Connect it before the solinoids. This way, if you are low on fuel pressure the NOS will not work.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
