MSD 8977
Old Apr 30, 2006 | 01:49 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
MSD 8977
i have my msd8977 digital timing controller all wired up for the most part, thanks to willie......just a couple questions to anyone that has one, when using the 2 or 3 step rev limit controls, do you still need a latching relay to hold the line lock on when you stage the car, or does the box do that as well? I can't seem to find any info on it, and MSD is obviously closed until tomorrow.
Old Apr 30, 2006 | 08:30 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Kevin,
Glad to hear you've basically got it installed already! I never did find anyone else here using the 8977 or even the 8979 (without boost control) but you might get lucky before Monday....
BTW, the timing retard that's programmed in the 8977 when you got it won't work for you. It's set for an altitude of 3100 feet. I'm assuming Massachusetts isn't that high!
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
sreZ28
Oct 22, 2015 08:21 AM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
