MSD box mounting question????
Old May 14, 2001 | 12:23 PM
idrag2's Avatar
Where should I mount my MSD 6A box? I need some opions.
Thanks I DRAG 2
Old May 14, 2001 | 05:21 PM
maniacc's Avatar
With my new ATI supercharger kit, came a battery relocator, which moved the battery forward and toward the radiator, this piece would be easy to make, also you could call ATI, and just have them ship you one. But anyways it provided me enough room to mount my MSD box on the fender next to battery.
hope this helps
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7L,edelbrock TES,random tech cat,borla exhaust,chip,sfc,accel wires,airfoil,k&n's,ETC..
and NOW supercharged!!!
http://maniac.megamania.com
Old May 14, 2001 | 07:14 PM
Tadder's Avatar
I mounted my MSD on the fender too with my ATI blower. I did trash the stock overflow tank for and aftermarket one that I mounted in front of the a/c condenser. I like the box on the fender myself, but to each his own.
Old May 14, 2001 | 10:10 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I mounted mine on the firewall where the MAF relays were before I relocated them. This was a complete PITA because I used the rubber isolators and my hands are a little too big to fit into the heater cowl intake to get the nuts on the backs... it was a PITA!
When I redo the wiring I'm considering putting it in the passenger compartment.
--andrew
Old May 14, 2001 | 10:25 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I had to mount mine here not bad though
http://www.geocities.com/hecubus91/enginepics.htm
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~200hp shot/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
BRoss99
Aug 10, 2025 05:08 PM
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
redmaroz
Aug 16, 2015 11:40 PM
midias
Aug 15, 2015 05:07 PM
