attn : Guido
Old May 8, 2001 | 12:13 PM
BrianB's Avatar
attn : Guido
Where did you get that little intake setup on your car. The one that bolts onto the throttle body with the K&N cone attached. I can't find anything like that anywhere. I want to run mine under the car so it will catch some cooler air.
Founder of the Greater Cincinnati F-Body Association
1988 Yellow Trans Am GTA
Click here for photos
Old May 8, 2001 | 02:07 PM
Guido's Avatar
Car: 2000 Trans Am
I bought it used from someone.
It is a 4" piece of mandrel bent tube and its been smashed flat a little on the one end so that a piece of rubber will connect it to the throttle body.
I dont even know what part number the filter is, but it works.
Hope that helped ya some
Old May 16, 2001 | 09:24 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
Brian, if you want to go a possibly cheaper route, go to your local parts store and look at their industrial truck exhaust system book, it will have listings with sizes on it, look for a 90 degree bent one and get the measurements on it, then go measure your hood to see for clearance then look in the K&N catalog they should have for a conical filter with a 4" opening I designed mine for my TPI system using 3" radiator hose and 3" aluminized exhaust pipe, works great I used the hose to make the bends since no one could bend 3" tight enough. this may work or to just give you an idea on something.
'87 Monte Carlo SS,with '89 IROC 350,700 trans, blew up 3.73 posi stuck with crappy 2.73's neeed gears! hooker headers, flowmaster 2 1/2" exhaust true dualls, recently installed a set of alum vette heads 58cc, new cam for a paxton, recently installed paxton, OMG need a posi bad. So if anyone knows where a buick GN 8.5" rear is let me know.
R3500
Aug 24, 2015 09:05 AM
Guido
Dec 12, 2001 01:20 PM
Guido
Nov 25, 2001 09:54 PM
Guido
Nov 1, 2001 08:59 PM
Guido
Aftermarket Product Review
Sep 29, 2000 07:50 PM
