fuel problem help
Old 05-04-2006, 12:27 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
fuel problem help
I have a 1988 camaro supercharged 30 pound injectors 6:1 fmu 255 walbro pump i am having a 3/4 throttle ping so i put a fuel gauge to check pressure went on the freeway and at 60 mph fuel psi was 35 and at full throttle fuel jumped to 45psi,i`am using a fmu so my fuel psi should be over 60psi right not 45psi.
Old 05-04-2006, 01:47 AM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
45 psi is right around stock
Old 05-04-2006, 01:54 AM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
35psi is about stock for closed throttle(idle vacuum) and 45 psi is around stock for WOT. The fmu only increases pressure when in boost, where you in boost? do you have a booster pump? usually people use an inline booster pump to aid the high commanded fuel pressures by the fmu. my guesses are that your pump can't do that pressure anymore or the boost reference blew off your fmu.
Old 05-04-2006, 12:30 PM
antoine's Avatar
i have a walbro gss340 hi out pump
Ghettobird52
12-29-2023 08:23 AM
92camaroJoe
07-29-2023 07:57 PM
Glowsock
08-02-2020 07:36 PM
Infested
05-22-2018 11:56 PM
92camaroJoe
08-13-2015 06:07 AM
Quick Reply: fuel problem help
