75 - 125 nitrous shot gains??
Subscribe
May 28, 2001 | 02:25 PM
What kind of 1/4 mile gains can I expect with a 75 and 125 shot of nos. I'm already hitting high 13s, but my car is a daily driver and I want to make sure it would be worth the trouble and the risk. Internally it's stock.
"Why StockBastard?" you might ask. Well...
84 Berlinetta body w/custom paint.
92 front/rear bumper and ground affects.
89 IROC 350tpi engine w/lots of mods.
87 3.73 possi rear w/disk brakes.
86 interior w/IROC dash.
And finally, stock Vet rims from the early 70s.(same ones used on the 69ss)
ALL IN ONE CAR!!!
Reply 0
May 29, 2001 | 08:14 PM
1/2 to 1/4 a second if the traction is there..
Reply 0
May 29, 2001 | 08:21 PM
I have the NOS Powershot system (125 hp) ready to bolt onto my car.
While it highly depends on your setup... NOS has some examples of 1/4 mile gains for the 125 HP shot -
65 GTO, Before 14.01, After 12.70
77 Chevy Truck, Before 15.06, After 14.13
83 Mustang, Before 15.45, After 14.02
I would expect pretty decent gains with the 125 shot... a 75 would obviously yield lesser results but would be much more motor friendly.
Luke
94 Saturn SL (1.9L)
86 Camaro Berlinetta (5.0L) *TPI 350 In Progress*
[This message has been edited by sven86berlinetta (edited May 29, 2001).]
Reply 0
May 29, 2001 | 11:29 PM
that sounds reasonable. i'm going to get a sound tune up before i squirt. any advice on what to check before you install NOS?
ALL IN ONE CAR!!!
Reply 0
Jun 6, 2001 | 07:53 AM
Check your mixture. Make sure you're not running lean. Replace the plugs, especially if they're platinum. N2O and platimnum plugs don't get along. Get at least one step colder plug. Check your timing. I usually pull 1 degree of advance out for every 50 hp of the shot. Some people might say more, but that's worked for me. Use your head, and don't get greedy, and you'll be fine.
Reply 0
Jun 6, 2001 | 09:09 AM
NOS suggest 1.5 degrees of retard for every 50 hp of juice. I take out 2 degrees per 50, cause I run pump gas. I would rather be safe than sorry.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Reply 0
Jun 6, 2001 | 01:46 PM
yeah, winnings got the idea, 1.5-2 is a good amount of retard per 50 shot, the best thing to do is get an adjustable ignition timing so you dont have to keep going under the hood, you can just adjust it by the ease of turning a ***. as far as checking the car out, EVERY ignition component, cap rotor, wires, plugs, mixture of course, and then make sure youve got plenty of fuel pressure and your pump functions like it should. youll really enjoy your nitrous and good luck.
Reply 0
Jun 6, 2001 | 07:46 PM
I raced with nitrous last night for the first time, my car is an 87 IROC 305 TPI auto. I used a 75(?) shot, 46N and 26F.
Before 14.67 secs @ 93 MPH
After 13.62 secs @ 102 MPH
So I gained 1.05 secs and 9 MPH with the above setup.
1987 Chevy Camaro IROC-Z. 305 TPI. 700R4
14.6 secs @ 93 MPH.
2.14 sixty foot.
Nitrous soon! :-)
http://www.camaro-firebird.org
Camaro and Firebird pages in Sydney, Australia.
Reply 0
Jun 11, 2001 | 10:52 AM
Look at my sig. My car goes from weenie to wicked.
1991 Firebird
350 L98 (was a 305 TBI)
T-5 transmission
Edelbrock TES and cat back
Accel manifold
NOS
subframes
jegster torque arm
MSD Digital 6
AFPR
Lakewood lcas
Hurst linelock
SLP cam (206 212 .480 .486)
relocated battery
cold air
Hypertech chip
centerforce df clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
a/f gauge
autopower rollbar
12.44 @ 114.63 juiced uncorrected
13.549 @ 102 non juiced uncorrected
Reply 0
Subscribe
