Times u think i can turn w/...??
Old May 28, 2001 | 05:09 PM
Killer-Z's Avatar
I have a 91z 305 5-speed w/3.42 posi rear. I have a Performance Resource chip, B&M ripper, centerforce D/F clutch, SLP full exhaust(cat-back and 1 5/8 headers), msd 6al and timing control, k&n airfilters and a NX dual-stage nos kit. I think im gonna use 100 shot for the first stage and 50 for the second in third and fourth gear. What times do u think i can expect w/this setup?? Do u think there is alot of time to be shaved off by doin the free mods? I got 14.7 w/just the chip, cat-back, clutch, and shifter. Thanks in advance Derrick
Old May 28, 2001 | 11:16 PM
IROC5.7TPI's Avatar
12.9x's at 106mph to 13.0x's at 103mph is my guess depending on weight and launch technique.
Thats using both stages.
Remember 305's have itty-bitty combustion chambers that are prone to detonation.
You better fuel that N2o system right or you will be scattering your motor all over the track.
Good luck
Mike L.
"If it feels good - stay in it "
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, airfoil, Random Tech Hi-Flow Converter (soon to go byebye!). ALL STOCK otherwise.
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Old May 29, 2001 | 10:17 PM
Killer-Z's Avatar
Anyone else...please-oh yeah and ttt. Derrick
Old Jun 11, 2001 | 11:12 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
use the 100 shot in first gear and then switch to the 150 in second-4th. I would put a clutch switch to shut off the juice when the clutch is depressed. my guess on time depending on launch is 13.2 @ 106
1991 Firebird
350 L98 (was a 305 TBI)
T-5 transmission
Edelbrock TES and cat back
Accel manifold
NOS
subframes
jegster torque arm
MSD Digital 6
AFPR
Lakewood lcas
Hurst linelock
SLP cam (206 212 .480 .486)
relocated battery
cold air
Hypertech chip
centerforce df clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
a/f gauge
autopower rollbar
12.44 @ 114.63 juiced uncorrected
13.549 @ 102 non juiced uncorrected
Car: 1991 Firebird
Engine: 427 LSX
1991 Firebird
T-5 transmission
Accel manifold
NOS
subframes
jegster torque arm
MSD Digital 6
AFPR
Lakewood lcas
Hurst linelock
relocated battery
cold air
Hypertech chip
AFR 190s
a/f gauge
autopower rollbar
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
TheExaminer
Aug 19, 2015 10:07 PM
Fronzizzle
Aug 17, 2015 02:52 PM
