Q for those who have a single turbo setup
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
How did you run your crossover pipe? Did you run it in front of the engine or around the back?
Most of the prefab ones that I have seen run under the back side. if you look @ the Turbo Tech setups, they use the stock manifold on the Drivers side & run a crossover back up into the bottom of the turbo manifold.
BW
BW
Engine: LS1 / LS3
The method of running the cross over around the back seems like a complicated idea. You would have to run one pipe to the turbo and then have to fight with the large down/exhaust pipe from the turbo. I would have thought that i would be much easier to just run it around the front of the engine.
Thanks for the info guys.
Doobie52
Sep 11, 2015 06:19 PM
