another blower question.
Old Jun 25, 2001 | 01:37 AM
Buzcarlos's Avatar
hey whats up guys,well i wanted to know how much much powerwould my 305 get w/ a ati super charger with the following mods isky .486" cam 350 heads w/port and polish,edlebrock torker intake,600 cfm holley,under ddrive pulleys,holley strip fuel pump and all the ingition stuff like timing ,msd 6al,boost retard,dui distributer,accel ferrero wires hooker shorty headers,spintech muffler ,gutted cat with straight pipe,accel header plugs.sorry for it being long.thanks for reading or respoinding.
j.p.
J.P.
84 Z-28 L69
rebuilding engine parts include:Ported heads and maybe intake,cam and lifters,push rods,rocker arms,gear drive,MSD6AL,HEI rebuild,Spintech muffler,hooker comp. shorty headers,Center Force clutch,
Old Jun 25, 2001 | 01:31 PM
maniacc's Avatar
First what compression are you running at???
Next, you'll need to swap over to a serpentine belt system if you already have not.
Then you'll have to set your carb up to perform as a blow-thru carb. also you'll have to get a carb bonnet to attach the system to the carburator.
And finally, you'll have to check your cam specs for valve overlap, the more valve overlap you have, the more it will hurt the performance of the supercharger. allowing the fuel/air mixture to blow right out that spintech muffler.
I'm sure there is other things to consider that i may have forgotten. but this should get you going for now
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
ATI procharger D1sc 10#'s boost, edelbrock TES, complete MSD ignition, Borla cat-back, KB subframe connectors, accel 24# injectors...and a few other go fast goodies
http://maniac.megamania.com
[This message has been edited by maniacc (edited June 25, 2001).]
Old Jun 28, 2001 | 03:08 PM
92Camaro305TBI's Avatar
how do you find or figure your compression?
92 Camaro 305 TBI Automatic
2.5 high flow cat
2.5 pipes
3.5in tip
shift kit
Tinted windows(legal)
Spark plug wires and plugs...
Future mods.
Headers
O.E.
any other advise on getting to 300+ HP would be appreciated. Thanks
System = Sony explode 5000 CD/MD receiver
Rockford 6x9 Fanatics
Rockford 4x6 Fanatics
Rockford 2 12" Hx2's
Custom box
Rockford 1 farad cap
Rockford 800x2 Amp
4gauge wire kit
Old Jul 7, 2001 | 02:19 AM
67muscle's Avatar
Check out KB piston site it's got the formula to figure it out but you need alot of the numbers like gasket thickness, head cc, piston cc etc.
To the original question asker you might want to look into some 58cc chamber heads. 305s had 58cc and 350s usually have 64 or 76 except some newer one have 58 like I think the vette. a 64cc head will give you a 1/2 point of less compression over a 58cc head and a 76cc head will give a full point drop over a 64cc head with all else equal.
And for some brutal honestly I'd ditch the 305 for either a 400 or 350 block. With all the dough your spending on the procharger etc it's in your best interst to. Hell you might not even need a procharger with good 350 and a small shot of the juice for those times when you want a little umph. IMO you won't be able to reap the benefits of the Procharger without at least better rods unless you just wanna burn up the 305.
Old Jul 10, 2001 | 03:17 PM
ATOMonkey's Avatar
The only thing he has to worry about is picking up pistons off the pavement. The first WOT on a stock shortblock with all of those ponies will pull the main webs right off. It'll do that way before he burns up the engine because that little carb isn't jetted right.
'87 Bird 350 .060 over 700R4 + Lots more
Old Jul 10, 2001 | 11:29 PM
kevin v's Avatar
have you already tried to run this as a blow through system? if it's done right you'll make good power with that 305 and have a blast. don't rev the p*ss out of it and respect the pump gas with lower boost and there's no reason for it not to be reliable.
ZZ3Astro
Aug 13, 2019 12:57 AM
codeysabatini
Nov 10, 2015 04:07 PM
86IROC112
Sep 28, 2015 08:17 PM
buckeyecelt
Sep 24, 2015 05:50 AM
Ian Irvine
Sep 4, 2015 08:08 AM
