supercharger opinions???
Old Jul 9, 2001 | 02:58 PM
know_bull88's Avatar
O.K. guys I am trying to go supercharged but I don't know if these pauts will work.
I have a 350 .30 with trw pistons new crank and rods Comp cams xe286 and a pair of 76cc heads.If any of you guy were me given the parts that I named what would you do to get blown?
Old Jul 9, 2001 | 03:02 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
what's the Comp. ratio?
SUPERCHARGED 87 GTA: Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best ET & mph (Nat. Asp.): 13.567 @ 101.900 w/ a poor 60ft. Best mph: 104.3 -*100% NYS emissions legal*
http:// www.community.webtv.net/munks87/JustinsGTApage.com
VORTECH S-TRIM, Install completed 7/9/01: 10 & 15 LB. PULLEYS, HKS race bypass, Custom cold air, Swapped to serpentine. Best ET: High 11'S I Hope. We'll see July 14th @ E-town!
Old Jul 9, 2001 | 09:02 PM
9:0.1
Old Jul 9, 2001 | 09:19 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
That cam probably has a lobe separation angle (LSA) of 110°.
a cam with a wider angle will generaly have less overlap and will work better with a supercharger.
You can use that cam, it would just be better with one better suited to a forced induction application.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Old Jul 10, 2001 | 08:06 AM
what would be the ideal lobe separation for this set up?
Old Jul 11, 2001 | 12:21 AM
IROCKZ4me's Avatar
<font face="Verdana, Arial" size="2">what would be the ideal lobe separation for this set up?
</font>
That depends to some degree on the other specs of the cam. The idea is to minimize overlap. Meaning the time that both the intake and exhaust valve are open at the same time is minimized. Generaly if the duration of the cam is longer the LSA needs to be wider to reduce overlap. Usally at least 112° as a minimum for best cylinder filling. Most blower specific cam grinds are around 114°-115°, 114° being most common.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Oct 5, 2015 06:23 PM
Jlanz55
Sep 29, 2015 08:55 AM
