Okay, I'm still new at this whole car thing, and now I'm on my second camaro. It's a 86 Iroc with a 350 4bbl engine. I am going to get my friends 350 and rebuild it, then swap. I need to know what I should do to make it do 11's in the quarter though. My very rich friend said that he would give me $10,000 if I got it done. Oh ye of little faith. Please help me accomplish this goal.
BLOWER BABY, BLOWER!!
If I can do it with my 305, you can definitely do it with a 350.
Make sure you get that in writing!! You'll be 10k richer if you do.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig): 12.57 @ 111 mph.
Former Paxton (6-psig) & former 50-hp nitrous: 12.04 @ 114 mph.
ATI D1SC (5-psig):
12.26 @ 113.55 mph
ATI D1SC (10-psig): Projecting high 11's.
Future ATI D1SC (15-psig): Gotta catch them pesky 26-psig boosted TTA's!!
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Willie
ATI D1SC (5-psig):
12.26 @ 113.55 mph
Can I still get a blower if it's carbed?
Also I have a 750 cfm Holley, Edelbrock Intake and a Fireball cam that I am going to use on the engine.
[This message has been edited by pygmalion (edited June 28, 2001).]
yes you certainly can, they refer to them as roots, lll reccomend a good 11's combo first off being rebuilt l assume youll change the intake and everything ok start with 4 bolt main conversion, forged rotating assembly crank, rods, pistons, 8 1/2:1 compression or so, bore it out to a 355 (.30 over) a good supercharger compatible cam check out crane for that, good high-perf lifters, rockers, valve springs, a good set of high flow heads, 420 megablower, two 650 4bbl carbs
and since you got money to burn pretty much, you dont need to use a sawzall to cut a hole in the hood
trans work l'd reccomend a good TH400 trans that will require a conversion kit, and a good ford 9 inch rearend with 4.11-4.56 ring & pinion. now lm bein real general here, but that should get you pretty darn close to 11's with a good pair of slicks...... and although it wont be a real gas saver-l'd say it'd be pretty streetable assuming you dont drive in the rain
trans work l'd reccomend a good TH400 trans that will require a conversion kit, and a good ford 9 inch rearend with 4.11-4.56 ring & pinion. now lm bein real general here, but that should get you pretty darn close to 11's with a good pair of slicks...... and although it wont be a real gas saver-l'd say it'd be pretty streetable assuming you dont drive in the rainMember
There's about 30 different ways to get to the same goal. My way was 9.7:1 forged pistons, 650 mechanical Holley, Sportsman Pro heads, ZZ-9 cam, 3" dual exhaust, 3.73 gears, 27" Hoosier Quicktimes, still got the 700r4, stock posi diff with a support cover, and 175 shot of N2O.
Dude ! 11's on a budget ? definitely go with spray. a cheater kit is like 3 bills, my friend ran a 355 in a 79 Z that runs 11.40's on the motor! his bottom end wasnt a dipped in gold deal every body says you need. quick run down. 355 11.5:1 forged ,AFR 190, BILL MITCHELL 750,.565/.570 (cant remember the duration)250&.050? 106 LSA,3" duals, 3800 stall th350 , 4.10 gears. this dude wasnt made out of money, but is a great tech. this car has been running for 4 yrs now without any breakage, with a 125 shot it ran 1.52 r/t and 7.05 @107mph.
good luck bro thats just my .o2
87GTA ,10.5:1,4-bolt 355,afr 190's, super ram ,stock poerted base,58mmTB,24 lb FMS inj. ed wright chip, .510/230 (nr) 1&5/8 hooker shorty's, flow master single 3", 2800 ameri-torque non lk-up, 3.73. best to date with stk 48mm tb and lack of traction in 1st gear netted me a 12.9 @110mph
/91 TA daily driver LB9 A4 2.73,
sitting in the garage : 26-11.5-16 et streets, sphon LCA's &rlb's, SFC's, b&m mega shifter....hope to install before the next century!!!
/91 TA daily driver LB9 A4 2.73,sitting in the garage : 26-11.5-16 et streets, sphon LCA's &rlb's, SFC's, b&m mega shifter....hope to install before the next century!!!
This is just my opinion... no flames please!
I would go with forced induction (i.e. turbocharger or supercharger). If youre on a budget, get a centrifugal blower (Paxton, Vortech, ATI, Powerdyne, etc). I'd get an intercooled ATI kit, mainly because their kits come with air-to-air intercoolers. You will either have to convert your car to serpentine belt, or get the "universal" kit from ATI.
The reason I say get the centrifugal blower instead of a roots blower (B&M, WEIAND, etc) is because of the following facts...
1- Centrifugals are more efficient (mechanically and thermally).
2- No need to cut a hole in the hood.
3- Not as much as a "dead giveaway".
4- emissions compliance(?). We know that the Roots blower isnt gonna pass any emissions test, especially when they do the visual inspection!
Now, I would stay away from nitrous because...
1- If it isnt tuned right... bye bye engine!
2- If there is a failure in the fuel system, bye bye engine!
3- If you dont use it properly, bye bye engine!
4- If youre racing someone and the bottle goes dry, bye bye money!
5- When you have to refill the bottle, bye bye money!
6- If you lie and say theres no nitrious on the car and your competitors find out, bye bye future races for a while!
7- If you get caught by Johnny Law with nitrous in the car, bye bye car!
Get it? Got money to get your car out of the impound? LOL!
BTW... they do make blow-through carb kits! You dont need EFI to run a Procharger!
[This message has been edited by JAYDUBB (edited June 30, 2001).]
Quote:
<font face="Verdana, Arial" size="2">Originally posted by quickL98:
this car has been running for 4 yrs now without any breakage, with a 125 shot it ran 1.52 r/t and 7.05 @107mph</font>
1.52 reaction time? Is he retarded? Was he in a comma? Was he getting a blow job while he was staging?<font face="Verdana, Arial" size="2">Originally posted by quickL98:
Quote:
<font face="Verdana, Arial" size="2">Originally posted by pygmalion:
Did you have to change anything inorder for the n2o to work?</font>
The only thing I changed for the nitrous was the forged pistons instead of hypers. I knew I could get a bigger shot out of forged. As long as you tune it properly nitrous is your friend.
[This message has been edited by Formula-91 (edited June 30, 2001).]
Thanks to everyone that has participated. That really helps me out. Thanks.
1986 Red Iroc-z (just got it)
350 4bbl
Edelbrock Open air element
350 4bbl
Man you don't even need a power adder for that. Get a set of tfs 23 degree heads a beefy cam and a stout bottom end. get a set of 456 gears and a 6 speed. drop the clutch on slicks at 6000 rpm and there you go 11's. if that is not enough spray in a 200 shot and go 10's.
90 IROC l98
last season best corected 13.62 @102
mods
full exhaust, AFPR, pulley, jet stage 1 chip, billet servo, 52mm throttle body, slp runners and some 1.6 RR's and a few other little things.
243 RWHP and 342 RWTQ with hot engine and 90 octain fuel
90 IROC l98
mods
Quote:
<font face="Verdana, Arial" size="2">Originally posted by JAYDUBB:
</font>
BWHAHAHA <font face="Verdana, Arial" size="2">Originally posted by JAYDUBB:
</font>
Originating member of the SJNEP Crew
Vice President of the Jersey Fbody Crew(JFA)
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Is nitrous illegal? What Jaydubb said about NOS led me to draw this conclusion, why else would a cop impound your car if you had NOS?
89 RS 350 TBI auto Hooker SC/LT headers Open element 3in K&N CVT protorque mini-starter
Daily driver 91 RS auto LO3 63k
New project- 89 Formula 350 WS6
383 or 400 to come!
383 or 400 to come!
No nitrous is not illegal and nor is it illegal to have it in your car....at the MOST they'll just check if the bottle is off and that I even doubt they'll do.....obviously they frown on you using it on the street mainly because you have to be at WOT to engage it if your smart and at WOT on the street you'll probably (most likely) be flying...not good when going by an esteemed upholder of the law...
-Brian
-Brian
Having NOS "armed" is illegal in certain states and provinces. Double check for where you live.
What exactly does "armed" mean?
383 or 400 to come!
383 or 400 to come!
Quote:
<font face="Verdana, Arial" size="2">Originally posted by RyanSS:
</font>
I'm in Maryland. It has something to do with HAZMAT laws. Since the nitrous is stored at 900-1100 psi, I guess they think thats dangerous or something. I've seen cops issue tickets for $1000 and up for having nitrous in your car. Funny thing is, if the line isnt hooked up to the bottle, they wont give you a ticket! Hmmm.....<font face="Verdana, Arial" size="2">Originally posted by RyanSS:
</font>
</font>
</font>
Armed= bottle valve open.
I was just reading an article that Georgia is busting chops for just having the bottle. I guess NOS is the "root" of all their street racing problems! Yeah right! I can see the HAZMAT deal, cause some states have tunnels, but just having a bottle and getting a ticket is BS.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
You don't even need forced induction or spray to get into the 11's. I should be there the next time at the track and I still have the stock 350 bottom end.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Tim
By the time he gets done getting to the 11s he'll be lucky to break even. The cheapest way I know is 9 inch slicks and as much nitrous that you can fit in one car. I'd blow up a stocker for 10 g's. Hot Rod ran a junk yard 318 into the 12's I think like that.
'87 Bird 350 .060 over 700R4 + Lots more
Yea, do that....300 shot of N20 into your motor and pray that it doesn't blow up before the finish line and you've got your 11's....
with the 10k you can then build a killer motor.
A well documented n/a combo that will put a 3200 pound car into the 11's could consist of a 350 with AFR 195's, Victor Jr intake, 850 carb, 1 3/4 headers and a 240/245 @.050 roller with .550 lift. Spin it to 6500-7000 rpm and see 500+ hp. For use with 3000+ stall converter and 4.11 gears and slicks.
1988 T/A,
9" Ford, 3.50 gears, Auburn posi, 700r4 -w- 2100 converter, 360ci, 9.8:1 cr,
AFR 195 Heads, Weiand #7525 intake, Lunati roller 219/227, .479/.480, 112 LSA
GM big block 2bbl TBI on truck 7747 computer
1988 T/A,
