oil lines for turbos?
What size should the lines be for the turbos and were should i get the oil feed from the engine? Can i get the oil pan off the car without lifting the engins so i can run the return lines? I know i need to have the fittings above the oil level so i don't have the return lines backed up. Car is 89 iroc 350fi. I'am finaly getting close to actual buying and construction of my twin turbo 350 efi.
Thanks Andrew i found your setup, two more question.
Is there a plug behind the back of the intake your used your feed from? I have yet to take a look its hard to see. I know the sending units back there on the block. Can i get my oil pan off with out unbolting the engine? Thanks
Street Lethal
Apr 30, 2019 12:14 PM
ambainb
Apr 25, 2016 09:21 PM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
