Nitrous on my Camaro???
Old Jul 15, 2001 | 04:09 PM
ziskz28's Avatar
I need expert advice please!!! I have a 87 Z28 with 50,000 miles on it. Mods are roller rockers, headers, open element air filter, not cat converter, no a/c, no smog pump/filter. It runs like a monster. As is, can the engine handle a 150 shot of nitrous. Someone please help me soon. Thanks.
Old Jul 15, 2001 | 05:01 PM
jmp1999's Avatar
Most of the time I have heard that with a motor with stock pistons, and crank, etc.
That you dont want to go with more than 125 hp shot. i also reccomend the fuel saftey cutoff switch. For like 30 bucks its a good investment to keep from blowing up the motor.
Old Jul 16, 2001 | 01:03 PM
MouseCamaro305's Avatar
i agree with jmp- fuel cutoff is the best investment a nitrous user can get. i don't know about the fuel pump- I've been running 150 HP shot on my stock internals 305 (70,000 mile on it)- it's been running terrific since i've installed it, and I've run about 7 or 8 bottles through it so far. just make sure your ignition/fuel system is up to par, other than that I can't see a reason as to why you shouldn't run nitrous through it
Old Jul 17, 2001 | 04:53 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
If you are worried about using a kit that is too large, only use it for higher rpm and be sure that you can feed it enough fuel also start with a healty dose of ignition retard and work your way up.
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
