Quick, need info on a procharger FMU
Old Jul 18, 2001 | 03:01 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
How does this work? Does it sense boost and then raise the fuel pressure? would this be a good item to get for a turbo install, rather than the $700 for the super fueler.. or would i need this as well?
Old Jul 18, 2001 | 07:55 PM
maniacc's Avatar
Omega,
Yes, the FMU works off of boost, as it senses boost, it starts closing off the fuel return line, raising the pressure in the fuel system, The ATI FMU is also adjustable, for tuning, but it is somewhat considered a bandaid, the proper way would be to use a superfueler system or properly sized injectors with either a accel, speedpro, haltech programmable ecm or even a custom burnt chip and the proper size injectors
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
ATI procharger D1sc 10#'s boost, edelbrock TES, complete MSD ignition, Borla cat-back, KB subframe connectors, accel 24# injectors...and a few other go fast goodies
http://maniac.megamania.com
Old Jul 19, 2001 | 10:03 AM
Omega's Avatar
Engine: LS1 / LS3
Cool, thanks... i should start saving for the superfueler then.. doh!
Bubbajones_ya
Jul 6, 2024 08:32 PM
armybyrd
Sep 28, 2023 12:16 AM
tmellott89
Oct 14, 2015 02:06 PM
-=Z28=-
Sep 24, 2015 10:21 AM
mackjar66
Sep 14, 2015 01:17 PM
