turbo and a stock 730 ecm...how will this work?
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
well i have seen that you can run a twin turbo or just a single turbo setup off a stock ecm with tuning...how good can you get the motor tuned with just the stock ecm and boost...would the tunerproRT and the ostrich be a good choice? i would like to do a turbo setup somday, i dont have any forged parts but the motor is not staock. all my parts are in my sig...with that said whats the max boost i would safley want to run on a 730 ecm and the motor/parts i have? not sure what heads ill be runnin but i was lookin into some aluminum l-98s "113s" with port work! it would also be nice to find a turbo off a stock turbo car....to keep cost down a bit...what would be a good turbo to run if im lookin to run say 3-8lbs...would this be a safe amount on my setup? just need more info on how to go about a setup like this...thanks
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
You basically have an engine that is set up like the one I have in a Camaro. Do a search for "another twin turbo camaro" here under the Power Adder board. It is a 355ci, 730 ECM, 7PSI of turbo boost.
Terrell351
Jun 13, 2021 01:13 PM
