Procharger Intercooling?
Old Aug 5, 2001 | 05:37 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
I was looking at my Procharger brochure the other day and noticed that they have placed the air to air intercooler directly in front of the radiator (it appears that way). I have a transmission cooler there now, so I'm wondering if their intercooler would fit up in there. Anyone know the dimensions or anything that would be useful to know about it? Thanks
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, Edelbrock Headers, Catco Cat, K&N, MAF Sceens Removed, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Bosch Platinum Plugs, Accel 8.8 mm Wires, MSD 6AL, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace
Old Aug 5, 2001 | 06:38 PM
maniacc's Avatar
IROCET,
Well i know from first hand experience, the ATI brochures and installation manuals, leave little to be desired.... but the aftercooler mounts horizontally in front of the plastic air dam...
This intercooler is the 3 core.
Also if you decide to go with a ATI kit, you'll have to ditch your March pulleys, Hypertech chip, and platinum plugs.
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
ATI procharger D1sc 10#'s boost, edelbrock TES, complete MSD ignition, Borla cat-back, KB subframe connectors, accel 24# injectors...and a few other go fast goodies
http://maniac.megamania.com
[This message has been edited by maniacc (edited August 05, 2001).]
Old Aug 5, 2001 | 07:09 PM
IROCET's Avatar
Engine: 5.7L
maniacc-
Two more questions about the intercooler. First, how far back does it go? What I mean is from the front of the car, how far back does it go toward the plastic deflector for the radiator cooling? Second, have you had any cooling problems or higher engine temps with the intercooler installed?
I knew I was going to have to get rid of the pullies when I did a super charger, but why do I need to dump the Hypertech chip and platinum plugs as well? Do you have to use the stock chip, or can you use an aftermarket chip by another company?
Sorry for the numerous questions, but I appreciate the help.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
Old Aug 5, 2001 | 08:08 PM
maniacc's Avatar
IROCET,
The intercooler takes up just about the entire area that is open from the front bumper to the plastic air dam...it stops about 3 inches before the air dam...
I have the 160 t-stat and 175 fan switch and the car runs about 185 - 190 degrees F. on a 85 degree day(10-15 degrees hotter than before the s/c)...and i still have all the A/C intact
The hypertech chip has TOO much timing programmed into it...your engine will not last very long...you can use a aftermarket chip as long as its programmed with the s/c in mind. I personally am using the stock chip with no problems (knock on wood), and the car ROCKS!!!
The platinum plugs tips stay hot and cause detenation ...
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
Terrell351
Jun 13, 2021 01:13 PM
sleprock
Oct 1, 2015 09:39 AM
sleprock
Sep 24, 2015 04:33 PM
-=Z28=-
Sep 24, 2015 10:21 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
