will my engine take a 150 shot or more?
Old Aug 4, 2001 | 02:23 AM
83CrossfireBomb's Avatar
i just put in a used 350, it seems to have a cam a step or two above stock, single plane high rise weiland, 750 vac secondary, HEI.
i was wondering what tests and other things i should check before installing nitrous and how much i could run.
thanks
former 305 crossfire fuel injection
350 cubes
hooker headers
750 vac secondary
700r4 with shift kit
Old Aug 4, 2001 | 08:11 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
You said that it was a used engine so I will assume it has a stock bottom end. I'm not gonna tell ya that it want live spraying a 150 HP shot on it, I just don't think it would live for very long. I would say stay at or below 120HP shot to be safe, take out a couple degrees of timing and make sure your fuel and ignition systems are in good working order. You also may want to do a compression check on the engine since it is used before ya start spraying it.
Old Aug 5, 2001 | 12:51 AM
i wish i could remember right now how to identify a steel crank. i read somewhere that you can tell by a casting mark. it comes to a point or edge and one comes to a flat ridge, but i cant remember which.
i have the oil pan off right and im gonna look and see if i can tell which that it has. took the pan off cause oil pressure wasnt as high as id like so im really really hoping a new high volume pump will help that.
Old Aug 6, 2001 | 12:19 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Cast cranks have a broad parting line that you could see on the rod throws, cast cranks have a very small line. If they are ground down though, it's tough to tell.
Old Aug 6, 2001 | 03:49 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<font face="Verdana, Arial" size="2">Originally posted by JoelOl75:
Cast cranks have a broad parting line that you could see on the rod throws</font>
Should that be forged cranks?
Old Aug 9, 2001 | 04:14 AM
JoelOl75's Avatar
Ooops my bad, yep, a large parting line is forged...
[This message has been edited by JoelOl75 (edited August 09, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
