What would be a good cam and heads for my SCed car?
Old Jul 24, 2001 | 12:21 AM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
I was wondering what would be a good cam and heads for my car with the supercarger and mods?
91 Camaro Z/28 5.7
SLP catback
SLP runners
SLP 1 5/8" headers
TPIS airfoil
160 degree thermostat
Rebuilt 700R4(borg warner/raybestos clutches,Kevlar band,vette servo)
B&M 2400 stall torque converter
Paxton SN92 Supercharger
Old Jul 24, 2001 | 02:39 PM
Greenshamrock77's Avatar
TFS 23 deg heads: Cheap, flow awesome, aluminum, only make 3hp less than AFR 190's, great quality. Do not confuse these with the TFS twisted wedge. These are POS heads, bad quality.
ZZ4 cam: Cheap, Ideal S/C specs, great lift, factory quality.
82' Z-28. 327" w/ flat tops. 216/228/112LS. Pocket ported 041 heads 1.94/1.50 SS valves. World Class T-5 from a 91'. Best run? Runs with 2001 vette to 150mph! Soon to be converted over to TPI w/ supercharger.
Old Jul 25, 2001 | 10:27 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
<font face="Verdana, Arial" size="2">Originally posted by Greenshamrock77:
</font>
Dont believe eveything you read in these boards
Daz
Old Jul 25, 2001 | 12:06 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
What do you mean by that?
91 Camaro Z/28 5.7
SLP catback
SLP runners
SLP 1 5/8" headers
TPIS airfoil
Old Jul 25, 2001 | 03:36 PM
Biochem's Avatar
Car: 2002 SOM z28
I think Daz runs TFS heads...
Any good flowing head will do. AFRs flow really well, especially at higher lifts. If your cam only has 0.5" or so, then it may be overkill.
Most cams for nitrous are dual pattern grinds. A good exhaust lobe and exhaust flow numbers for the heads is quite nice for nitrous.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Jul 29, 2001 | 12:09 PM
Matt383's Avatar
I agree with split duration cam. Exhaust should be roughly 10 degrees more. Also watch lobe seperation. Around a 112 would be good. If going AFR, look into 195's as opposed to the 190's. They will give you a little more intake volume and not really hurt your low rpm intake velocity that much.
Matt383
w/ ATI
Old Aug 10, 2001 | 12:28 AM
Bruce89TA's Avatar
Car: 89 Firebird T/A
I thought a higher lobe separation was ideal for supercharging. I'm trying to decide between my stock cam and the SLP cam that I bought.. It's got a 112 degree lobe separation while my stocker has a 117 degree lobe separation. I've got an 89 Firebird with a 305 TPI. Anyone have any comments?
Bruce Chang
ICQ #2992488
89 Firebird Trans Am
305 TPI, Jet Airfoil, Hypertech Thermomaster Chip, Edelbrock TES, Hotchkis LCA's and Panhard Rod, B&M Shift Kit, March Power Pullies, Suspension Techniques Lowering Springs, Flowmaster Muffler, Accel Super Coil, Energy Suspension motor mounts, tranny mount and torque arm bushing
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
Fronzizzle
Aug 9, 2015 01:15 PM
anesthes
Aug 8, 2015 09:37 PM
