procharger and SD
Old Sep 9, 2001 | 07:54 AM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
procharger and SD
i know SD is less forgiving than maf is when adding bolt ons however can you run a supercharger on a stock 90-92 SD f-body since all you are doing is increasinng the pressure in the manifold will the stock programming except it.or will the fuel map be a little lean now that you are shoving serious air into it?if not how would you guestimate how much cfm is now flowing into the engine to set the air fuel ratio or is it a big guessing game.
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
car has found a new home
she will be relocating soon,thanx to all that were interested and the few who had purchased some of the many,many extra parts i had accumulated over the years.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
Old Sep 10, 2001 | 04:47 PM
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
c'mon guys anybody running this setup?
best e/t:
Old Sep 10, 2001 | 06:06 PM
Jason M 91Z's Avatar
The FMU adds more fuel by increasing rail pressure anyway, so boost fuel addition is independent of the type of closed loop fuel metering (MAF or SD).
-Jason M. 1991 Camaro Z28
sleprock
Oct 1, 2015 09:39 AM
sleprock
Sep 24, 2015 04:33 PM
-=Z28=-
Sep 24, 2015 10:21 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
