larger tb with supercharger
per my last post it seems that the concences is that a larger tb will provide some gain over the stock unit even on a supercharged application--that being said then how big is too big?should i get the 58mm and just be happy knowing there is nothing bigger(other than the mono blade) or should i get the 52mm and try to keep the velocity of air passing thru up?any reasons to get one over the other?
thanks
pete
1990 Trans Am,350 TPI(L98),WS6suspension ,bridgestone RE71's /245/45/zr16
paxton supercharger,afr heads, alston sfc's,msd 6AL-BTM,
8.5 superconductor wires SLP 1-3/4 headers,duel cats,3"slp exaust, lakewood LCA's,T.B.Bypass
160 degree stat,alum driveshaft,fiberglass wing, secret mods
"if you cant win fair CHEAT"
thanks
pete
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
If you are using the stock plenum you will need to port match the inlet to get the benifit of the 58mm T-body. If you don't want to do that the 52mm will bolt right up with no port matching required.
With aftermarket heads I believe the 58 won't hurt you. I also feel the larger T-body bores will allow the plenum to be filled quicker and the supercharger will keep the velocity high through the T-body at least when under boost conditions.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
'86 IROC-Z Camaro
"Cogito ergo zoom"
- 355 cid
- AFR heads
- Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
- modified SLP runners
- TRW forged pistons/ceramic coated
- fully balanced
- Edelbrock headers/ceramic coated
- SLP cat-back
- Paxton supercharger
- Nitrous Express nitrous oxide
1 vote for vthe 58mm anyone else?running a 58 with no adverse affects?
edelbrock manifold,asm ltr's
paxton supercharger,afr 190heads, alston sfc's,msd 6AL-BTM,
160 degree stat,alum driveshaft,fiberglass wing,custem chip by me!
toronto formula
Nov 10, 2015 06:17 AM
dbrochard
Sep 19, 2015 08:13 PM
