turbo tpi?
Old Sep 27, 2001 | 01:13 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
turbo tpi?
how can you do this?
or should i sell my tpi setup? got the turbo...got the car...also have a 750cfm holley carb in the garage.....
but i want to keep my low-end torque, so how can i setup a turbo tpi?
Old Sep 27, 2001 | 02:30 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
You will never have to worry about torque again if you size your turbos properly. I am seeing full boost at 2000 rpms, way before the peak torque of the NA TPI engine, so it's a boost all the way across the board.
Andris
89 IROC T56 DFI Twin Turbo
http://www.skulte.com/turbo.html
Old Sep 28, 2001 | 12:27 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
how did you fit the turbo to the tpi unit? did you go directly to the TB? what about manifolds to go from the exhaust to the turbo?
Old Sep 30, 2001 | 12:05 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
I made my own intake/intercooler ducting by buying aluminum mandrel bends from Burns Stainless, and fabbed the intercooler end tanks from sheet aluminum (all tig welded). Prior to the IC setup, I made the turbo to throttlebody ducting from dynomax mandrel bends cut on a chop saw and mig welded (I didn't have a tig at that point). The exhaust manifolds are the restrictive Gale Banks cast iron units. I hope this helps.
Andris Skulte
Skulte Performance Designs
Z28tt-89 IROC T56 DFI Twin Turbo
Terrell351
Jun 13, 2021 01:13 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
