a few questions about upgrades
Old Oct 31, 2001 | 08:34 PM
quickL98's Avatar
Car: 87 trans am GTA
Engine: tesla permanent magnet
Transmission: 93 T-56
Axle/Gears: moser 12bolt w/ 3.73
i was thinking about upgrading to a roller with similar specs as my current hyd cam. i'm loooking at a crane power max (87 prior ) .509/.528 with 284/292 adv. duration. will going to a roller be worth the cost , and should i put my 1.6's back on if i get this cam? the cam i have now is a .480/.480 292 with 1.6's on it, i believe comes out to .510
i'll have tio call them and find out the LSA is first
with hypereutectic pistons how much spray can safely use , with the proper fuel and timing adjustments(the motor does have studs top and bottom)
thanks to anybody who takes the time to give me some advise
87GTA ,10.5:1,4-bolt 355,afr 190's, super ram ,stock poerted base,58mmTB,24 lb FMS inj. ed wright chip, .510/230 (nr) 1&5/8 hooker shorty's, flow master single 3", 2800 ameri-torque non lk-up, 3.73. best to date with stk 48mm tb and lack of traction in 1st gear netted me a 12.9 @110mph /91 TA daily driver LB9 A4 2.73
Old Oct 31, 2001 | 08:45 PM
quickL98's Avatar
soory i need spell check
updated my signature also....bad october for me..huh?
87GTA ,10.5:1,4-bolt 355,afr 190's, super ram ,stock poerted base,58mmTB,24 lb FMS inj. ed wright chip, .510/230 (nr) 1&5/8 hooker shorty's, flow master single 3", !!!!!DECEASED ameri-torque non lk-up converter and 700r4!!!!, 3.73. best to date with stk 48mm tb and lack of traction in 1st gear netted me a 12.9 @110mph
rebuilding the stock tranny with a trans -go kit and H/E materials plus a 3500 vigalante and subframes and 4.10
Old Nov 3, 2001 | 01:43 PM
quickL98's Avatar
would a solid roller be more beneficial?
Old Nov 3, 2001 | 04:37 PM
superstreet's Avatar
It is worth going to a roller cam.The faster ramp speeds allows you to have more duration because it slams the the valves shut faster and the cam can be more aggressive (and a plus,you don't have to break it in like a flat tappet cam).Did the block come with a roller cam?Does it have provisions in the lifter valley for the lifter retainer clamp tray?I would still run the 1.6 rockers (are they roller too?) You will have to set the lash on a mechanical cam,probably a couple of times a month,depending on how much you race or drive it.It is up to you if you want to go with a solid roller,I have one but don't run it on the street.As for the nitrous,hypereutectics DO NOT like nitrous,you will have a melt down!You need forged pistons.
Frozer!!!
Jan 19, 2024 04:55 PM
NinjaNife
Aug 23, 2015 11:49 AM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
