Can you make a hobbs pressure switch work backward?
Old Nov 8, 2001 | 02:22 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
If i understand correctly, a pressure switch is used to prevent the NOS from switching on if the fuel pressure is below a certain point. I get the impression that the circuit to the arming switch (or something) is opened by the pressure switch. Well I want a pressure switch to close a circut. I need to figure out how to make an electric vacuum pump activate when the vacuum drops below a certin point. Any suggestions?
Old Nov 8, 2001 | 05:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
www.worldmagnetics.com
Old Nov 9, 2001 | 07:51 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
thanks. I have since found this
http://cgi.ebay.com/ebaymotors/aw-cg...item=597553217
and it turns itself off.
but i will use that as plan B.
Old Nov 9, 2001 | 08:08 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You can get Hobbs switches in Normally open and normaly closed and in different pressures.
Try NAPA/UAP Parts stores
MustangBeater20
Oct 29, 2022 09:20 PM
TheExaminer
Aug 26, 2015 04:59 PM
jackhammer
Aug 15, 2015 10:04 PM
Fronzizzle
Aug 9, 2015 01:15 PM
gwade12
Aug 8, 2015 08:17 AM
