Drag Racing: Best way to fire nitrous...
Old Nov 14, 2001 | 04:07 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
As for engaging the solenoids, I see a few options and was wanting to know which you all preferred for drag racing. My kit is equipped with a full throttle switch. In-line and before with this switch, I will wire a master nitrous arm switch. The switch can either be a momentary button (such as a thumb switch on the shifter) or a switch on the dash. Which is best for the dragstrip?
Ford red 1991 Formula 350. ROH 16in wheels, 1998 Grey Leather, street/strip 700r4 2400 stall, EIBACH springs, Strut tower brace, Poly Bushings
3.73 SLP POSI, 26 spline Moser Axles, mid SLP cam, grear drive, SLP runners, 24# injectors, Taylor wires, Accel Coil, Accel Ignition, B&M Megashifter, K&N conical, AFPR, SLP 1 3/4 coated shorty headers, 3in cat, 3in. mandrel-bent single exhaust, flowmaster, TB air foil, 180 stat, SSM SFC's, SPOHN lower control arm adapters, custom burned prom, Hotchkis Lower control arms, Aluminum Driveshaft, ported upper and lower, an assortment of autometer guages, 14 speakers and q-logic kick panels. And this thing is still slow!
Instant Messenger JMatlock88
Old Nov 14, 2001 | 05:26 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
It's just a matter of personal preferance and needs.
A fuel pressure safety switch wired in there is a nice safety add-on. Your piston tops might thank you some day.
A lot of people like to use an adjustable RPM switch. Many of these are reffered to as window switches because they switch the system on at a certain RPM and back of at a certain RPM (ie: on at the minimum RPM you want the system to engage and off right before the rev limit).
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Old Nov 15, 2001 | 09:19 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
First off, I used a semi complicated switching mechanism to operate my system. Then I found that I can't shift and hold a button at the same time. I just arm the system and the final trigger is my full throttle switch. That is what I recommend.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Nov 15, 2001 | 10:54 PM
JMatlock88's Avatar
Car: 1991 Formula
Thank you all for your input!
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RS Reaper
Oct 17, 2018 07:52 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
JSDaddy189
Sep 26, 2015 03:50 PM
indygene
Sep 26, 2015 11:21 AM
