Attention LT1 conversion folks- Nitrous Plate?
Old Dec 10, 2001 | 06:49 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Will there be enough clearance for a nitrous plate to be sandwitched between plenum and TB? From pictures, it is hard to tell whether the IAC/TPS can be clearanced further into the belt tensioner or if further clearance is impossible. Multiport or fogger as an alternative? Any advise or ideas on the matter is appreciated.
Ford red 1991 Formula 350. ROH 16in wheels, 1998 Grey Leather, street/strip 700r4 2400 stall, EIBACH springs, Strut tower brace, Poly Bushings
3.73 SLP POSI, 26 spline Moser Axles, mid SLP cam, grear drive, SLP runners, 24# injectors, Taylor wires, Accel Coil, Accel Ignition, B&M Megashifter, K&N conical, AFPR, SLP 1 3/4 coated shorty headers, 3in cat, 3in. mandrel-bent single exhaust, flowmaster, TB air foil, 180 stat, SSM SFC's, SPOHN lower control arm adapters, custom burned prom, Hotchkis Lower control arms, Aluminum Driveshaft, ported upper and lower, q-logic kick panels.
Instant Messenger JMatlock88
Old Dec 11, 2001 | 11:41 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Most of the LT1 kits are a dry setup, single nozzle injecting the nitrous in the bellows before the TB and after the MAF, then fuel pressure is raised to add fuel, the only plate LT1 kit i know of is by Nitrous Works, NX makes both a single nozzle dry, and a multiport wet setup, I may end up with the multiport myself, check www.racenet.net for them.
Old Dec 11, 2001 | 09:00 PM
JMatlock88's Avatar
Car: 1991 Formula
Is there a problem running a plate-type TPI nitrous kit between a TPI TB and an lt1 intake? You are saying that they dont recommend plate type kits for lt1's, instead they recommend a fogger nozzle?
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
L0tuS
Oct 4, 2015 08:07 AM
mygta87
Sep 14, 2015 10:36 PM
drb930
Sep 9, 2015 10:53 PM
L0tuS
Sep 4, 2015 11:16 PM
