Installed tubular k-member this weekend
Old Dec 3, 2001 | 10:11 AM
Guido's Avatar
Car: 2000 Trans Am
You can see how much room is saved by looking at the brake line in the first photo. It bolted flush to the stock k-member and is not even close to the new one.
-86 IROC
-=ICON Motorsports=-
Old Dec 3, 2001 | 11:01 AM
87Z-ya's Avatar
Looks good. Did they recomend not using it on a car that road races? I'm interested but am curious about the strength of it.
Old Dec 3, 2001 | 11:05 AM
Guido's Avatar
Car: 2000 Trans Am
If you purchase a mild steel version then you will be alright. They say the chromoly ones arent as durable for road use.
Old Dec 3, 2001 | 01:27 PM
Project86Iroc's Avatar
Guido, just out of curiosity, would that be strong enough for a street driven daily driver? I like the simplification, the weight reduction, and the extreme ease to get to , say, the oil pan, starter, and brake/tranny cooler lines. BTW, what do they run?
I would love to be there when those Muslim Bastards hit the Pearly Gates and realize they were wrong...
Old Dec 3, 2001 | 01:52 PM
Guido's Avatar
Car: 2000 Trans Am
Yea I would trust it for a daily driver.
Check out the website for the place I bought mine from.
www.paracing.net
They have prices and a contact number. They can answer more questions then I can.
Old Dec 3, 2001 | 04:18 PM
89ROC's Avatar
That is niice Guido. Just doesn't look quite as strong as the factory k-frame, but long as its strong enough you should be alright
I bet it will make everything 10x easier and will be well worth the $479.
Are you going to use Rack & pinion steering?
Old Dec 3, 2001 | 04:34 PM
maniacc's Avatar
Guido,
That looks sweet, did ya have to do any modifications to get it to fit properly?
later
larry
Old Dec 3, 2001 | 05:08 PM
PROCHARGED89Z's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Guido:
If you purchase a mild steel version then you will be alright. They say the chromoly ones arent as durable for road use. </font>
Guido,I haveheard this from Jim to,he told me the same thing ,but I called PA,and they told me a diferent story.Told me the Chromemoly,is welded differently,almost makes it look like a machined piece.He told me either one is fine for anything I would want to do with it.Just told me what ever your preference.I asked him about the steel one being better for the road and he told that was not true.
By the way are you going with the manual steering rack too?
Check out my Hompage,or the beginnings of one.355 dynoed at 400HP at 5800RPM & 410LBFT of TQ,on Motorhttp://www.procharged89z.cz28.com/index.html
Old Dec 3, 2001 | 08:05 PM
JERRYWHO's Avatar
Guido:
What type of front motor mounts are you going to use.
I see in the picture the front motor mounts cut off.
Jerry
Old Dec 3, 2001 | 08:46 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Thats a good question,why did you cut the motor mount pads off?You run a V8 and should have no problem with the supplied ones,even I was able to leave them in and weld up the mounts for the V6(see pic)
Steve
1989 Turbo Trans Am's #124 and #850
1989 Turbo GTA,600hp 3.8L SFI TURBO
2001 Kawasaki ZX-6R
www.tta850.com
Old Dec 3, 2001 | 09:50 PM
Jester's Avatar
Steve: I'll go ahead and answer for him. It's because he's running a motor plate. Doesn't need them.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Dec 3, 2001 | 09:52 PM
blown87gta's Avatar
Car: 1987 Pontiac TransAm GTA
Engine: Vortech S-Trim, 355cid
Axle/Gears: Mosier 12bolt, 3:73 Eaton locker
<font face="Verdana, Arial" size="2">Originally posted by JERRYWHO:
Guido:
Jerry
</font>
If I'm not mistaken, motor mounts are an "optional" extra-cost item....
FWIW, here's my tubular K-member (probably
seen it before) and I have no fear about
open road racing it. http://www.applink.net/~thartman/K-member.htm
hth,
T.
Old Dec 3, 2001 | 11:16 PM
Guido's Avatar
Car: 2000 Trans Am
Like Jester said, I am installing a motor plate. I am having my roll cage finished up this winter and putting struts through the firewall and attaching to that.
Old Dec 3, 2001 | 11:23 PM
JERRYWHO's Avatar
blown87gta
I found this on Guido's home page
"I Cut the motor mount pads off of the k-member since I decided to go with the front engine plate."
Now a question for you about the k-member that you linked is it still in production. one of my racing friends runs a open road 3rd gen and he was looking to upgrade his car. I think going 209 mph is fast but he wants more. Please let me know more about it if you can.
Jerry
Old Dec 4, 2001 | 03:15 AM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
blown87gta,thats a nice looking k-member there.Looks a bit heavy though.Are those caster/camber plates avalable and from where?They look like they would be a nice addition to my PARacing setup scince I'm using coilovers also.
Guido,looking good,sorry to ask a stupid question,I remembered you were going with a motor plate about 10 minutes after I posted
Thanks,
Steve
2001 Kawasaki ZX-6R
www.tta850.com
Old Dec 4, 2001 | 06:06 AM
blown87gta's Avatar
Jerry
</font>
See http://www.roadtechonline.com but I doubt he has them listed yet. I don't know how many he has, but the weight w/mounts is about the same (maybe a little less) than the stock K-member. I used one for header & oilpan clearance (looks cool too eh? )
The Castor/camber plate is an integral part of the coilover kit. I don't know if it's sold separately or not. I would ask how you are mounting the PARacing kit at the top if you are NOT using some sort of custom plate?
Road Tech's email was listed in the pictures,
but I'll post it again; roadtechonline@yahoo.com
hth,
T.
Old Dec 4, 2001 | 12:57 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
The PARacing kit slips right over the struts and fits right up to the stock mount.The springs on the PA kit are not that long they are regular coilovers.I'll try to get some pics of it soon.
I was just wondering about them cause they look stronger than stock and scince I'm gonna replace them anyway,but if they are a part of the kit I'll stick with the stockers as they are strong enough.
Steve
Old Dec 4, 2001 | 05:24 PM
blown87gta's Avatar
<font face="Verdana, Arial" size="2">Originally posted by TTA850:
Steve
</font>
So the top "mount" of the PA racing coilovers
just presses upward on the -stock- strut mount?? Wow, I'd be scared $hitless that those three smallish bolts holding it on would fail... I would appreciate any pictures you have though.
I'm going to try to post some pics, hopefully it'll work right.
hth,
T.
Old Dec 4, 2001 | 11:18 PM
You want to see how coil overs look go to my homepage in sig and click on pic page 1 its down near the bottom,Art Morrison coil overs.
Old Dec 5, 2001 | 02:33 AM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
I'm not worried about the bolts as they have been replaced with grade 8 fasteners I was just asking cause I'm always looking to improve anything I can on my car.
Steve
2001 Kawasaki ZX-6R
www.tta850.com
Old Dec 12, 2001 | 01:24 PM
Gta-Paladin's Avatar
Alright someone show some patience, when i ask what a K-member is and what it's function is.
Old Dec 23, 2001 | 11:20 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
this is a k member, the thing under the engine as seen on the left hand side of this picture https://www.thirdgen.org/rides/rideimages/Mvc-135s.jpg
Old Dec 25, 2001 | 10:55 PM
TTA's Avatar
TTA
Steve you put a K-member in? I want to do the same thing, actually I have to so the girdle fits. I wish they made one with Mounts for the V6
So you got the one with coil overs and all that huh? I just want one I can bolt all the stock stuff too.
You didnt weigh the stock piece did you? I wanna know the weight savings...
Old Dec 26, 2001 | 02:16 AM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Mike I havent weighed them but scince it's out of the car again I'll do it tomorrow and let ya know.
Steve
Old Dec 28, 2001 | 10:17 AM
TTA's Avatar
TTA
Steve did you get a chance to check the weight?
Old Dec 28, 2001 | 04:31 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Sorry not yet,I checked the tubular one but have to go dig out my old subframe to measure.I'll post it tomorrow for sure,promise
Steve
Terrell351
Jun 13, 2021 01:13 PM
BADNBLK
Nov 16, 2016 09:12 AM
justin57
Aug 20, 2015 07:05 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
NBrehm
Aug 5, 2015 07:57 PM
