Supercharger Help
Old Jun 28, 2006 | 10:32 PM
irocz06's Avatar
Supercharger Help
Hey guys i need some help on picking the right charger, I have an 87 iroc but vortech and procharger say only the 88 and up will work. any particulars on this.
Thanks for info
Old Jun 28, 2006 | 11:13 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Some conversion work needs to be done.
I also started with a 305 TPI 87 iroc. I new that the v-belt configurations wouldn't work. So I had to make some investments. I had to purchase a new Waterpump, Smog-Pump, Alternator, Idler Pulley, A/C compressor and A/C lines, a Serpentine Belt, and mounting brackets for everything. I bought almost everything at Advance Auto Parts several Years ago and didn't keep the receipts, but when you go to the store for the swap, Just tell them it is for a 91 Z28 Camaro. Worked Great for me.
I ended with the the Vortech Package. I am still in the process of tuning the ECM and am currently hitting a few other small tuning issues. I had to eliminate the MAF system and go S/D.
Old Jul 11, 2006 | 11:27 AM
rgreen78's Avatar
Why did you need to go to speed density? Did you have to replace the entire engine harness?
Old Jul 14, 2006 | 09:02 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Supercharger Speed Density ~VS~ MAF
The Choice to switch to S/D was a easy one for me. As I am in the process of converting the engine to major modifications that MAF can't handle. You can use the existing Wiring harness but you have to repin the new 730 ECM and memcal. You also have to add a MAP sensor which can use the MAF wires from the 165 ECM. Mass air flow systems are great if you want to make minor engine modications to the engine. I have personally found that a 730 ECM with a AUJP eprom is even easier to modify especially for adding the fuel for a Supercharger application. I have the repinning charts and almost all the information if you are considering this.
Old Jul 15, 2006 | 10:35 AM
Steven89Iroc's Avatar
In short... You don't have to switch to speed density, though it's not a bad idea.
You do have to swap over to the newer serpentine belt setup, that's why they're not listed for '87 and older.
Old Jul 15, 2006 | 04:40 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Supercharger Serpentine system
Yes he is 100% correct. I have the vortech and I had to do a full serpentine conversion to run it. Which consists of New A/C pump, Air Pump, Alt, Water Pump, You have to add an idler pulley.
I have to have the air pump on my car because of NY state emissions. It doesn't have to work properly, just be there just like Catalytic Convertors.
This can be accomplished faily cheap if you get all the brackets from a junkyard and go new like Advance, Autozone, and automotive store. Don't go dealer for these parts unless you have tons of money to throw away. I think to switch to serpentine system, The conversion total price was around $600 but that was dealer brackets and idler puller and the rest Advance.
I thought at 1 time Paxton made a S/C for the 87 TPI with v-belts but I can't find the info on it any more.
InfinityShade
Feb 21, 2016 01:29 PM
toronto formula
Nov 10, 2015 06:17 AM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
