anyone ever use oxygen for more power instead of nitrous??
Old Jul 2, 2006 | 10:32 AM
dennisgramm's Avatar
Car: 1983 Camaro Z28
Engine: 5.0L HO
Transmission: 5speed
Hi, I read all the extra hp sources to increase power, what would happen if you would put a bottle of pure oxygen instead of the nitrous, and run it instead? I am assuming someone has either tried this or maybe blew himself up...just curious...I know oxygen is suppose to enhance burning. Appreciate a reply, thanks, Dennis
dennisgramm@verizon.net
Old Jul 2, 2006 | 10:54 AM
Time2Fly's Avatar
Car: 1991 Z28
Engine: 400 ci LS3
Transmission: Jerico DR4
Pure oxygen would create too much heat.
Old Jul 2, 2006 | 01:30 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
its too dangerous, my grandfather though about using it years ago but ruled it out as too dangerous if something every happened, maybe you coul duse liquid oxygen , but i dont know if a consumer could get it .
Old Jul 2, 2006 | 02:47 PM
daves12secV6's Avatar
pure oxygen will ignite when it mixes with oil
Old Jul 2, 2006 | 06:36 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Even bearing grease will burn violently in a pure oxygen environment.
Old Jul 3, 2006 | 02:36 AM
83 Crossfire TA's Avatar
You wouldn’t be able to add a significant amount without causing problems… it would probably start with either issues with keeping from blowing your intake apart or if you did manage to get it in the engine you’d probably end up using the piston tops as fuel…
Old Jul 3, 2006 | 06:53 AM
Engine: 5.0L HO
Thanks to all who responded
This confirms what I expected, appreciate the good info, would not want an early fourth of July under the Hood. Dennis
Old Jul 10, 2006 | 12:21 AM
loud_mouth22's Avatar
Car: trans am 86
Engine: 383
Transmission: 700
im pretty sure nos carrys an extra molecule of oxegen thats why you add more fuel
Old Jul 12, 2006 | 06:50 AM
honkeytonk_man's Avatar
Car: 1988 IROC-Z
Engine: e-tec headed ZZ-4 350
Transmission: t56
Axle/Gears: 9 bolt 3.7 posi
Wanna see what Oxygen and atomized fuel can do? Check out Cutting Torch-Petrogen Oxy-Gasoline System USA I've used their cutting torches and they blow away acytelene on thick steel, they clain up to 14" of pentration with a scraping tip! Not what I want inside my engine!
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
