were to put o2 sensor on tubo car??
Old Jul 5, 2006 | 07:14 PM
daves12secV6's Avatar
for all u turbo guys were did u guys put ut o2 sensors,i mounted mine about 3 inches away from the turbo outlet,and im having a hard time getting a stable reading.Would i be better off with the o2 on the inlet side of the turbo rather then the downpipe?
Old Jul 5, 2006 | 09:41 PM
vwdave's Avatar
I think its too close to the turbo. I would put it back a little further.
Old Jul 6, 2006 | 01:02 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
If you put it before the turbo then it will see too much pressure and not read correctly. So don't do that.
I am guessing that you have a stock 1-wire O2 sensor. Due to it being away from a heat source to be in the active range it is cooling off and not reading properly (output justs wiggles a little). It does not do full swings.
That is what happens when they don't have enough heat. A 3-wire would solve the problem and is recommended.
That is all assuming that the O2 sensor is good to begin with. Check to see if the output is swinging after a good run that heats the downpipe. If it is swinging then it shows the O2 sensor is good and you need a 3-wire sensor.
Old Jul 6, 2006 | 08:02 AM
thnx man im gonna go out and get a 3 wire 02 today,did some more reading up on it,and it seems many ppl have had the same symptoms i have when using a 1 wire o2.hopefully switching to a heated o2 will help.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Fronzizzle
Sep 8, 2015 12:10 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
willyjoejr
Sep 3, 2015 09:26 AM
