twin turbo advice needed
Old Jul 11, 2006 | 03:50 AM
evilzee28's Avatar
I'm gonna be putting together a jy blow through twin turbo GM 406 with eagle crank, rods, je pistons , dart pro 1 heads with 215 runners & 72cc chambers,(comes out at 8.5-1 compression). I have full machine shop facilities to make headers etc. Could any one please tell me what size turbos I should use (A/R etc). I'm looking to make around 500+ bhp. I live in England so I'm unable to get turbos from American cars easily, but have been told that volvo or Saab t3's would work, is this the case? I must admit that I don'rt fully understand how to read maps. Any advice would be greatly appreciated. thanks
Old Jul 12, 2006 | 09:50 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Twin t3's will probably be too small for that engine. You're going to want to find bigger turbos or even just one big one. You could always try eBay.
If you are new, read this info on getting started
Old Jul 13, 2006 | 05:18 PM
Steven89Iroc's Avatar
Here is some good information including how to read compressor maps.
TurboByGarrett.com - Turbo Tech101
TurboByGarrett.com - Turbo Tech102
TurboByGarrett.com - Turbo Tech103
Old Jul 20, 2006 | 03:39 PM
head's Avatar
Car: 1984 MSE #52
Transmission: TH700
See ta84-355's post . Twin Turbo 84 -Finally running
Old Jul 20, 2006 | 10:24 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
you can get a new master power t70 for, i believe, around 500$ US. they are good to around 600-650hp. it would be a single setup.
Old Jul 20, 2006 | 11:49 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I don't know a lot about turbo stuff, but I would stay clear of turbos from a automotive engine. You would be spinning two T3s too hard/fast and also getting poor efficiency (hot intake air). Maybe two Buick GN turbos at a minimum.....but difficult to find in England.
With a proper cam that engine will be close to 500HP without turbos. I would be looking at JY diesel turbo (T4) units for the twin setup. Total HP guesstimate would be in the 600HP to 1000HP range depending on the boost, intercooler, cam, exhaust.
Terrell351
Jun 13, 2021 01:13 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
