turbo help
Old Jul 23, 2006 | 06:49 PM
86irocterror's Avatar
turbo help
guys i dont know anything about turbo's but im tossing ideas around about my engine set up and want to know if you can turbo a carbed engine. and if you can what is involved in doing it? i never seen a turbo that wasnt on fuel injection and i dont know much at all about turbo's so thats why im asking if it can be done. thanks guys
Old Jul 23, 2006 | 08:26 PM
RDriedger's Avatar
Car: 84 Firebird
Axle/Gears: posi & 3.73s
Yes, you can run a turbo on a carb. You'll probably want to run a blow-thru setup which requires some modifications to your carb, such as floats. For all the information you could possible want to know on boosting, check out TurboMustangs Forums - Index although it is primarily for mustangs there is a small block chevy section.
Good luck if you do go boost, I plan on boosting my 305 in the spring.
Old Jul 23, 2006 | 09:29 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Just start reading...
Turbochargers - Hugh Macinnes
Thinking about going blow-thru........please read these threads first
If you are new, read this info on getting started
I also did a write-up on my single turbo blowthrough setup on my cardomain site.
http://www.cardomain.com/ride/764085/2
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
