2 Fuel pumps broken???
Old Jul 28, 2006 | 12:24 PM
daverr's Avatar
i have two big blue billet vortech fuel pumps in series.I run about 20 psi of boost. At idle my fuel pressure is at 45 psi. So 45+20= 65 psi fuel pressure at full boost.When i go full boost my fuel pressure does not go above 50 psi.So i ran a test where u had to run the pumps and adjust the fuel regualtors to 65 psi. U then took fuel out the return and measured how long it took to fill a gallon. Well in three minutes i didnt have a half gallon.i was told i should have at least 150 gl/hr flow at that pressure. Is it common for fuel pumps to go bad like this??? do they offer rebuild kits??
Old Aug 2, 2006 | 03:32 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Im a bit confused as to why they are in series, parrallel is what is done for volume.
Old Aug 2, 2006 | 03:40 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
also how long have you been street driving these pumps? most of these pumps although some will last a while on the street, others won't. Its not a "by brand" thing. Its more of a "by luck" thing.
Old Aug 2, 2006 | 03:41 PM
daverr's Avatar
my mistake the pumps are installed parallel.each pump feeds it`s own fuel rail.
I have 1 aeromotive A1000 and was thinking of getting another one to replace the 2 paxton pumps.
Old Aug 2, 2006 | 03:46 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
are you running an FMU? Im guessing from the "So 45+20= 65 psi " comment that you are not. Try the single A1000 and a trip to the dyno to see if it is ok. Also consider having the other two pumps flow dynoed.
link: Fuel Injector Services - RC Engineering
Old Aug 2, 2006 | 03:56 PM
daverr's Avatar
No FMU.
My fuel system is setup for two pumps ,i would have to plug the other side up.I called up Paxton about my problem , the first thing they told me was the pumps i have are old and no longer carried by paxton. They wanted to sell me two replacement pumps for $545 each. but I already have 1 brand new a1000 pump and would just need another one.The thing is im hearing good and bad stuff about the aeromotive pump.
Old Aug 2, 2006 | 04:16 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
like I said, have RC dyno them
maybe only one is bad.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
92camaroJoe
Aug 13, 2015 06:07 AM
